Need help. Trying to remember what this paper that lights up.
skywalker311
Hey everyone, I'm trying to remember what this material was called. The best way to describe it would be led light paper.
You get it in a sheet that looks like a piece of paper. You then can cut it into shapes and then add electricity to it to make it glow. I've found some thing similar to it. It called Sing Light Sheet but that not what I'm looking for. I saw back when the 360 first came out and people started mod the 360 they would use this thin like paper to make their cutout logo glow.
If you know what it called and can send me a link to where I can buy it and how to use it that be great.
Phanteks enthoo primo, i7-4770k, ASUS MVIF, 16GB G.Skill Trident X Ram, ASUS 780 Ti DC2O, Samsung 120GB and crucial M500 480gb SSD, 1TB Western Digital Hard Drive, NZXT 850W power supply
EK Supremacy, EK ASUS MVIF Water Block, EK Monarch Series X4 Ram, EK ASUS 780 Ti DCII, EK 420 Cool Stream Rad, XPSC 240mm RAD,Monsoon Series Two Dual Bay Reservoir, Swiftech MCP655-PWM-Water Pump, Monsoon Compression Fittings & Tubbing, Mayhems Pastel Red with Mayhems ultra pure h20.
xeromist
EL tape?
Also note that if you etch and edge light acrylic it can look pretty good. Depends on what you're trying to achieve.
