Need Help Cleaning/Accessing My Laptop Keyboard Keys
tackyjan
Hello All!
I recently spilled soda on my ASUS ROG GL752VW-DH74 17-Inch Gaming Laptop
and today I decided to be brave and take the entire top off thinking I could access the keys to clean them.
59099
On the underside of top piece that has the keyboard there is a silver bracket that doesn't appear to have any screws (except 4 tiny screws that I found under some black tape).
59100
59101
Is there a way to remove this bracket to get to the keys and ultimately be able to clean them? Or perhaps I am going about it the wrong way, and should be accessing cleaning the keys from the top?
Thank you,
Jan
P.S. Assuming I can not go any further in terms of accessing the keyboard does anyone have a recommendation as to how I might clean the keys so they no longer stick? Since the keyboard is completely off the chassis (and away from any power source) would it be safe to clean with water and/or perhaps a little alcohol? :e
0 REPLIES 0
