My Rampage 4 EX FULL Bitspower crystal link water cooling in a modded TJ11
sammwise
HEY there ppl.
This is my second WC build so i wonted to put some work in to it, and do something that i would be proud to put on display, well here it is 😄
System..
intel 3930k 4.7G @1.321v
Motherboard Rampage 4 Extreme
2 X Gigabyte GTX 580 1.5G SLI (plans for 2 GTX 780s in the future)
Sound card Asus Xonar essence STX
32G Corsair Dominator Platinum 2400C10 Running XMP profile
2x Corsair 120 force GE SSD's in RAID 0 R&R speeds 1G a second (BOOT)
2x Corsair F1 120GB SSD's in RAID 0 R&R 900MB a second
2x WD 10,000rpm Raptor Drives in RAID 0
2x USB 3 WD 2T External HDD
COUSTOM Bitspower crystal link Water cooling
Black Ice 560 Rad
XSPC Dual D5 pump and res
OS Windows 7
Modded Case TJ11
3x Asus VG278HE 144Hz 3D in Surround
278892789027891278922789327894278952789627897278982789927900279012790227903
A few thing i still need to do like cable management, Lighting stuff like that but its all most there, so thank you for your time and interest 😎 O and i would love to know what ppl think, as its my second build i am so happy with the way it all unfolded and the support and KNOWLEDGE/HELP that i have gained from ppl like you is and was the only resin i was able to finish this build, i cant THANK YOU ENOUGH...
Sam
4 REPLIES 4
vanakka
Man, very impressive! I have to say I love how you did the watercooling most, it has such a "solid" look to it. Just one question, are you going to leave it without the side panel? (if not, can we see a pic with the panel on?)
NZXT Phantom (white/blue), ASRock Fatal1ty 990FX, ASUS HD7850 2gb, FX8150, 1TB 7200x HDD, 240GB Sandisk SSD, 16GB G.Skill Ares 2x8 @ 1866, Corsair 650w.
sammwise
Thank u so much 😎 As for the side panel i wont to make the window a bit bigger witch will get rid of the giant air intakes on the side and replace the clear acrylic with smoke acrylic it will cut out most of the uv light so you will only be able to see the components and coolant that's reacting with the light. Also the orange acrylic i used on the bottom tray is also uv reactive so when i get all the lighting don witch will be controlled with a LAMPTRON FC5 fan controller as well as the 2 D5 pumps it should look even better 😎
2798627987279882798927990
Sorry about the lighting and reflections is was difficult to get a good photo 😎
abvolt
Level 11
its looking really good dude nice work.
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Thanks man :):):)
