My first liquid cooling setup (XSPC + HAF X)
Sir_Slappy
So my XSPC Rasa 750 RX360 kit arrived today in the mail and I immediately set about getting it installed. I took my time and tried to be as meticulous as possible so I ended up taking around 10 hours to get everything done (including multiple breaks and eating dinner). It was pretty straight forward and was not too difficult to install. The only real issue I had dealt with the left-most 120mm fan installed on the rad..it pushes up slightly against both the 8-pin and 4-pin 12v cpu power sockets but they are both still fully seated so it should not cause any problems. Now it's time for some pics.
How the insides looked before I tore it all apart.
Everything stripped out of the HAF X
Old Hyper 212 Evo taken off and all old AC5 removed and ready for the new xspc rasa block.
Mobo installed back into case with the new cpu block installed. I tried to use the stock AM3 back plate and the black bolts but the bolts were not the right size for the back plate so used the silver bolts instead.
360mm radiator plus 3 Cooler Master 120mm Sickle flow red led fans installed. It may be a bit hard to see but the fan on the left completely covers both the 8-pin and 4-pin cpu power sockets. The fan did clear the NB heatsink with no issues though.
Reservoir/Pump being installed. I removed the SATA dock and the reservoir slid in nicely and was secured with the provided screws.
Got the tubing installed. In keeping with the ROG color scheme I used PrimoChill PrimoFlex Pro tubing in UV Red. It was easy to cut and install. Since this is a basic loop I went Resorvoir-->Radiator-->Cpu Block-->Resorvoir.
Finally, installed my XFX HD 6970 and the VGA cooling duct and did some last minute cable management. Not too shabby if I say so myself.
Loving the ROG colors!
Well, there you have it. My first impression of this kit is very good so far. I leak tested it for about an hour and not a single drop leaked out. I did end up using about 1.5 bottles of PrimoChill Ice so luckily I bought two with the kit when I ordered it. I will wait a week or so before I do any stress testing to compare my new temps to what I had when I was using the Hyper 212 Evo. This should give the Artic Silver 5 time to get some heat cycles in to get a good measurement of my new temps. Hopefully with this kit I will be able to over clock my 1100T to 4.3Ghz or maybe a bit higher. Thanks for viewing and tell me what you think!
Motherboard- Maximus VII GENE
CPU- Intel i5-4690K 4.5GHz 1.25Vcore
CPU Cooler- EK Supremacy (Acetal+ Nickel)
RAM- 16gb G.Skill 2133MHz 9-11-11-31 1.6V
GPU- EVGA GTX 780
SSD- OCZ Vertex 4 256GB
SSD- Samsung 840 EVO 250GB
PSU- EVGA SuperNOVA 750w G2
Case- CaseLabs SM5
OS- Windows 8.1 64bit
15 REPLIES 15
Granger
Looks very nice,
But I think you should take out the two top fans as their speed wont be the same as the fans on the rad (I beleive that having them there will lower the efficiency of the rad) But check your temps first, if you don't have a great gain in temperature in comparison with your old cooling system. Take out the 2 case fans and see if there is a difference (I'm pretty sure there will be).
Sir_Slappy
Yeah, I am planning on trying exactly that. Since I have installed this water cooling setup my temps have not lowered very much at all so far. I was thinking it was either due to me using too much TIM or due to the top fans. I did recently switch the fan on the back of my HAF X from exhaust to intake and noticed that did help a little with temps but tonight I am going to try removing the two top 200mm fans and see if my temps improve. I will try to report back after I have done some testing with the top 200mm fans removed and see if my temps drop.
GPU- EVGA GTX 780
Case- CaseLabs SM5
Granger
Leave the 140mm at the rear on exhaust and make your rad drag the air from the outside. That should lower your temps a lot.
What are your temps at idle and load ?
Thanks,
Mack 4033
I5 2600K O.C to 5.0 Gzh | Maximus IV Extreme B3 | 8GB P. Storm 2133 | EVGA GTX-580's in SLI |Crucial M4 256GB | Corsair AX 1200 | Corsair 800D | WC Swiftech Custom System Freezone E | Win7 Pro x64 * 3rd GTX 580 on the way*
hi to all at rog.asus.com i thought i had sent this newyears eve but it didnt send so i have sent it again all best for 2012 to every one
- matt
Mack_4033
Nice build I will post mine later today..
Thanks,
Mack 4033
Sir_Slappy
Ok, time for a quick update. I ran Prime95 for about 30 minutes before I removed the two 200mm fans from the top of my HAF X and my temps got up to 65/50 (socket/core). I then removed the two top fans and ran Prime 95 again for 30 minutes and my temps reached 59/45 (socket/core) so that right there was a very noticeable decrease by just removing the restrictive top 200mm fans.
My next step is to install the 3x 120mm fans that came with the xspc kit on top of the rad for a push/pull config exhausting out the top and check my temps then. After that is complete, i will switch the 6 120mm fans so that they all intake air into the case and I will switch the 140mm rear fan to exhaust and I will then again check temps using Prime95.
Currently, with my 140mm rear fan setup as intake and only 3 120mm fans my idle temps are 32/22 (socket/core) so not too shabby. This is with my 1100T overclocked to 4.0 Ghz and 1.425 Vcore in bios (AI Suite shows 1.404 vcore under 100% load during Prime95)
GPU- EVGA GTX 780
Case- CaseLabs SM5
Granger
Nice work, I think you should gain a few more degrees with a push/pull set up, and a few more again by dragging cooler air from outside of the case 😉
Sir_Slappy
Time for one last update. I finally received my last 3 fans 120mm fans and a Scythe Kase Master Pro 6-channel fan controller and got the fans hooked up to the radiator. So now the final fan setup for my HAF-X is this:
1x 230mm fan on front of case- Intake
1x 200mm fan on side panel- Intake
1x 140mm fan on rear panel- Exhaust
6x 120mm fans mounted onto radiator- Push/Pull dragging air into the case
This setup yielded the best temps by far and I am definitely happy with the results:
Idle- 28/19/24 (Socket/Cores/Mobo)
Load- 51/41/28 (Socket/Cores/Mobo)
Again, this was with an 1100T OC @ 4.0Ghz with 1.416 Vcore. Hopefully in the next few days I can try to reach 4.3Ghz and still keep the temps under 65 C.
GPU- EVGA GTX 780
Case- CaseLabs SM5
