Mad max / fury road gaming pc build
MonsterMawd
Level 12
Welcome! Thanks for checking out my tribute to Mad Max & his Interceptor build log. This is one of my Bucket list theme PC builds. My mother brought me to the premiere of The Road Warrior movie and I've been fan of this world ever since. This will be a modified desktop PC with liquid cooling. Inspired by visual elements of Max's Interceptor and the Mad Max World. ...and maybe Fury Road. There shall be rust and maybe even a Detonator attached to the PC? (lol). I'll be sharing highlights of it's progression stages, including video clip links as I move along in this thread. I have a basic idea of what PC hardware components will occupy this mad max inspired PC (motherboard, CPU, DDR, GPU, SSD, PSU) The case is an Enermax Equlilence they donated to me last year. If you've followed my past personal builds, I like to find good deals on hardware whenever possible I do plan to fabricate the liquid cooling lines from 361 marine grade stainless tubing. No idea what brand of CPU & GPU water blocks, radiators and fittings I'll use yet.
The case is the Enermax Equilence I was given. It sorta looks like a Fractal Case, but without any of the well thought out features.
I apologize in advance if you're expecting me to pose a Mad Max action figure inside the case (haha). The Interceptor's V8 feels more appropriate. The scale Ford engine I'm using is by LIBERTY Classics, http://www.libertyclassics.com/
I've added motorized shaft to spin the supercharger belt, you can watch it here, https://twitter.com/Mnpctech/status/992023385818492928
I've modified the supercharger pulleys with larger plates to keep the belt from rolling off.
I will be fabricating a new engine scoop to emulate Max's Scott Injector Scoop and painting everything dark grey.
35 REPLIES 35
That's location for the GPU with this do-it-yourself vertical mount. The final GPU will have water block.
Next stage is modifying the top rear portion of the Enermax Equilence case to hold two water reservoirs to emulate the rear fuel tanks on the falcon XB.
haha, the details are the fun part! Scoop done, Everything on the engine needs to be painted Dark Silver Aluminum
My apologies for the lack of updates. I've had to start another project build for a client. Paying gigs keep the lights on, so Max will need to temporarily park the Falcon. I may bring it out and share a new update for mental break if time allows. I will be starting a worklog for this new build once the NDA is lifted, I think it will be a real spectacle once it's finished.
I plan to get back on this Mad Max build, as it was supposed to replace my old shipping PC months ago*
Here's another chance to win a build of mine, just announced today by Cooler Master, https://landing.coolermaster.com/computex2019/campaign/*
MonsterMawd
Level 12
To emulate the rear fuel tanks in Max's Ford Falcon XB, I'm using EK-RES X3 150mm reservoirs. btw, these photos are stills from video I'm making of the entire build, once it finished for my YT channel, https://www.youtube.com/user/MonsterMawd
I'm wondering if I can use clips from the movie without audio in my video? no clue...
MonsterMawd
Level 12
Do you recall the Red pull switch on Max's stick shift for his Supercharger? I thought it would be fun to somehow implement it into my Mad Max tribute build. The switch is used in commercial vehicles for controlling a two-speed axle assembly. I found it on Ebay as Cole Hersee part number 50036-BX.
xeromist
Nice find!
MonsterMawd
Level 12
What do you use for cutting small holes? I made this guide for Step Drill Bits
https://www.youtube.com/watch?v=cVs3tLZQZ6g
I found Max's Falcon rim in web search attached Nikko Toyota HiLux 4WD R/C truck, but I'll check the R/C Hobby Stores
Our scale V8 sitting next to Black ICE GTX 80mm radiator. This morning I found 36mm thick 80mm radiator online shown below. Suppose Flex tube loop would be appropriate.
Last time I drilled some holes for bulkhead pass-through fittings I used a hole saw designed for deadbolt lock holes. Happens to be the right size. Step bit is more versatile though.
Ahhh, I could see using that! Had some time to get progress in yesterday. The Black Ice Nemesis GTX 80mm radiator may have won me over, instead of the scale appropriate generic radiator I was considering. It also allows options for different compression fittings, versus the welded ports.
