01-30-2018
11:31 AM
- last edited on
03-06-2024
09:16 PM
by
ROGBot
01-30-2018 04:29 PM
01-30-2018 05:45 PM
Chino wrote:
Upgrade is the best option. It'll be pretty hard to find a new motherboard that supports your CPU. Even if you did, it would be a used one probably.
01-31-2018 07:25 AM
01-31-2018 01:59 PM
offthewall69 wrote:
Did the socket pins break or get bent? While you're waiting for the funds to upgrade, bent (and sometimes even broken) pins can be repaired. Many videos on line that show the process; basically the tools you need is a strong light, good magnification, thin push-pin and sometimes a razor blade to re-align. It's tedious work, but if you're careful you could resurrect the board. If you go the upgrade route, you'll probably have to replace your cpu and ram in addition to the motherboard. Expect a hefty budget...
02-27-2018 01:52 PM
