HAF X top 200MM fans and Hidro 100i gt cooler
skysoldier83
Hello friends of the forum,
I am new at building PC and modding...so I am here to ask lots of questions.
I have a HAF X case with two (2) 200 mm fan on top and was thinking of installing of my new rig the Hydro Series H100i gts H2O cooler.
Now, when I install the Hydro do I need to remove the top fans or not really, also the fans of the Hydro are facing downwards or are
they facing upwards agains the case ceiling?
thank you for your answers
johnanthonyhome
There will be fans on both sides. Blowing IN.
Nate152
Hello skysoldier83
Have a look at this.
http://www.bing.com/videos/search?q=youtube+haf+x+h100i+installation&FORM=VIRE3#view=detail&mid=2CCA...
Tip:
He says to make the screws tight, but not so tight you strip them out.
The fans should have an arrow pointing which way airflow is going.
