Hi fellow modders,
It was a matter of time but here it is... my first real scratch build
Thanks to Nate from
E22 for the design.
Sometimes you see a design with a wow factor. This happend too me with this design. After some consultation we decided to try to build this design.
Nate the design and I'm building.
Sponsored by:
And designed by:
The design:
The hardware that comes in is still a suprise...even for me
😉 , but anyway there will be an SLI set and some cool watercooling
After buying aluminum strips and other stuff at the hardware store, it was time to start building. After some fitting and measuring the frame was created. I still had an old Mobo tray from a old TJ07.
Cut some plates of acrylic and placed it.
For measuring I have an old blown up Classified.
Made the door/ cover for the PSU
And cut to size the front plate
Now it's a matter of drawing lines on the inside. The result after sawing and filing.
Cut holes for the fans at the front and the lid on top covered with acrylic
Covers closed
Placed some nice 120mm
NorthQ fans to see how it looks.
More updates coming very soon
