fractal meshify 2 and arctic liquid freezer 2, lga 1700 not compatible
hoodiemike
just a heads up, if you want a beg radiator and a beg case, a meshify 2 and arctic liquid freezer 2 do not work on lga1700 mother boards unless you cut out a small rectangle, about 1/2 and inch by 3 inches on the motherboard plate so the cooler back plate can clear. also, the arctic liquid freezer does not fit on a rog strix gaming wifi e without trimming the vrm fan shroud. hope this helps in your choices
Simon_LeBon
IF this is the Arctic Liquid Freezer II... Arctic is aware of the situation and have both a temporary solution and a more permanent one.
Details here (with a list of all motherboards affected):
https://support.arctic.de/lf2-lga1700
