First Build with AIO - Formula & 8700k
r4dz1k
It took me 2 days to finish with this configuration, I had two problems, one of them was - the first RAM slot had contact with the hoses(many people had the same issue) but I knew I had to do the opposite way and in my opinion it looks better. The second problem I had with the cable from the pump, somehow the dog bit my USB cable which feeds the pumps but it turned out that it did not damage the cable, so I only put the insulation tape and everything works as it should. I bought all parts already in November exept MOBO I waited for it to appear in stores, but to be honest with u I had no time to build this rig becayuse i had a really busy time at work.. The processor is delided, temp idle is 25-30 not sure how it looks under load because I have not had time to play some games and see what the temp will be. I'm happy overall the last thing i have to do is to OC my cpu and thats all. I spent too much money 🙂
My question to you guys:
Do i need to change some options in BIOS if i connected my AIO to the CPU FAN header ? e.g. cpu fan pwm to ingore or something?
Any options in BIOS to make boot my 960 pro faster ? any magic options in BIOS?
Config :
CPU INTEL COFFEE LAKE 8700K
MOBO ASUS MAXIMUS Z370 X FORMULA
RAM G SKILL TRIDENTZ 32GB RGB 3600MHZ
GPU ASUS STRIX ROG GTX 1080TI OC
SSD1 SAMSUNG 960 PRO 512GB
SSD2 SAMSUNG 850 PRO 512GB
PSU SEASONIC PRIME ULTRA TITANUM 850W
CASE PHANTEKS ENTHOO LUXE WHITE
COOLER KRAKEN X62 REV2
Tuning :
Kraken AIO WHITE HOSES by CABLEMOD
NZXT AER-P 140MM WHITE RIMS
PSU CABLES SLEEVED WHITE/BLACK by Shakmod
PHANTEKS 1M LED STRIP
Photo:
https://i.imgur.com/EZvICl9.jpg
https://i.imgur.com/qn1aHKU.jpg
https://i.imgur.com/76jBYVC.jpg
https://i.imgur.com/KKS3vEL.jpg
https://i.imgur.com/k3OxK8Z.jpg
https://i.imgur.com/bH5Pkwa.jpg
Any question pls ask 🙂
BigJob
Looks so clean & nice. Good job! 😉
also, would have loved a whole case pic from a 7 to 10 feet distance to visualize the whole thing.
bender02
Looking good man, great job.
