First advanced PC Build
Skylinekrille
So after years of playing around with computers i decided to try build it with style.
And for some reason i wanted to give water cooling with hardlines a go, wasnt easy for a first timer
The setup camed down to this
Asus maximus formula VII
Intel 4770K @ 4,5gz
G.Skill Ripjaws 16gb 2400mhz
Asus Poseidon 780 x2 SLI
Corsair 750D
Asus ROG front base
Asus ROG Swift monitor
It also consist of 2 radiators, 1 larger at the top with 3*120 fans, wanted to make push/pull but case is to small so in future i will get a koolance shroud for the top of the case i think
also bottom is a smaller rad with 2*120 fans
Gonna post more pictures later, mobile pics is really bad in this dark enviroment
After some hours of bending its finally together with no leaks :confused:
I will do the sleeving to i think, but will do that later i think.
sWaZi_sKunk
Looking forward to better pics! Looks awesome with the MB in the loop!!
ROG2015 Back in Red&Black
NZXT.H440 ~ M7F ~ i7-4790k ~ Poseidon GTX980 ~ G-Skill 2400 16gb ~ 850Pro 256gb ~ ThermalTake 1050w DPS ~ VG248QE
abvolt
Level 11
you're rig looks really great, nice work..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
