08-05-2012 09:32 PM - last edited 3 weeks ago by ROGBot
08-06-2012 05:12 AM
08-06-2012 03:03 PM
08-07-2012 04:24 PM
Zka17 wrote:
My first question: when your CPU temps reaches 140F/60C? Is it under max load (like stress testing)?
Regarding the airflow, well you do have to experience that... you know, there are theories and there is the real life... - I just learned this recently too... :cool: The most important thing is to supply the coldest (ambient temp) air for going through your radiators... the way you achieve that is very particular to each setup... for me proved to be the top intake...
Having the top fans (those on the radiator) pushing fresh air from outside through the radiator into the case is a very good idea - your first setup... you just have to be sure that you can remove the air from your case... and forget the hot air thing from the radiator! - that's usually just slightly warmer then the ambient... if you have the correct setup - if you feel that the air leaving the radiator is warm/hot, then you're way over the limits! there is something wrong...
If the temps are getting hot inside your case, that's an airflow problem... have you calculated the intake amount vs exhaust amount of air?
And a notice at the end... I know, you didn't ask for, but will mention it... 🙂 Your PSU may run at it's higher limits... 750W for a 3 way SLI may not be enough for long time... specially as the PSU will get older...
08-08-2012 01:56 AM
08-08-2012 02:39 AM
08-15-2012 01:04 PM
08-15-2012 02:59 PM
ilidaan wrote:
The 240 rad is realy not enough for your current setup. The 8800 GTX are realy hot even in idile state. For your setup you realy need at least 480 rad and thick one to. U can easly put 3 x 120 rads 60 mil thich in that case and on the top 120 stealt GT rad. With changes in airflow u will not going to solve anything.
08-27-2012 09:08 PM
xeromist wrote:
This is true. Just for giggles I once tried 360mm worth of rad for a CPU and 3 8800GTX's and they were still hot so that is just waaaay short on rad surface for that build.
08-15-2012 03:53 PM
