start another build, this one is for me, my personal Gaming Rig
Snef's Bloody Angeli need more .........muscle......
but Horizontal board is not for me
i need a real "TOWER of POWER", at begening, Enthoo Primo white was my first choice
but i saw new case on caselabs store, The SMA8
i sent an email to caselabs to know the shipping rate
and i finally choose Caselabs SMA8
generally i try to search for a unique or special color combination but not this time
keep it simple
Hope you will enjoy it
Build setup/parts listing : Case and accessories • CaseLabs Magnum SMA8 White
• CaseLabs 120.2 Flex-Bay Rad Mount
• XXL Clear windows
• 480 rad mount on top and bottom
• Case Feets by Fannblade
Components • Asus Maximus VI Formula Z87 Motherboard
• Intel i7 4770K CPU
• Corsair Dominator GT 16GB DDR3-2133 RAM
• Asus Xonar Phoebus sound card
• Silverstone Strider 1500w PSU
• Galaxy GTX 780 HOF (2x) (waiting for Ti version)
• OCZ Vertex 4 256GB SSD (2x)
• OCZ Agility 3 240GB SSD (2x)
• WD Green 3TB HDD (2x)
Cooling • Bitfenix Spectre Pro BFF-LPRO-12025R-RP 120MM Red LED (16x)
• Darkside 480 Radiator (2x)
• Darkside 240 Radiator
• Darkside D5 Vario Pump (2x)
• EK-D5 X-TOP CSQ - WHITE Acetal (2x)
• EK-Multioption X3 250 with white acetal ends (2x)
• EK-UNI Holder D5 (2x)
• Bitspower White Crystal Links with a lots of extenders, adapters and 90 degrees
• EK-HD Tube 10/12mm 500mm - 2 pack (13x)
• EK Supremacy CPU Waterblock - Plexi-Nickel CSQ (polish)
• EK-RAM Dominator (CSQ) Waterblock - Plexi Nickel (polish)
• EK-FB KIT ASUS M6F - Nickel
• EK-FC780 GTX HOF - White Acetal+Nickel (2x)
• ColdZero Custom GTX 780 HOF backplate
• ColdZero Custom Xonar Phoebus backplate
• Ek Water Blocks Fluid Blood Red 1000ml (4x)
• Aquacomputer Aquaero 5 XT USB Fan-Controller
• Aquacomputer Ultra Poweradjust (3x)
• Aquacomputer Black Faceplate 5.25 Mount Tray for Poweradjust 2
• Aquacomputer Flow sensor mps flow 400, G1/4 (2x)
Sleeving, Cable and lightning • Darkside Red
• Darkside White
• Darkside Fan spliter
• Darkside Led strips
• Darkside 12" ( 30cm ) Dimmable Rigid LED Strip V2
• and a lot of custom cables
Mods• Painting ram
• Painting Waterblock
• Painting radiator
• Painting Pump mount
finally not so much mod, Caselabs generally dont need physical mod to acheive a good build
i saw we can order parts for any case now, i can drill some hole in midplate and back panel
some parts already in my hands, some are ordered and i will order the rest in march
i will try to do a little Video (Vlog) of every steps of this build, for sure, i will post a lot of pics
the first video will be
Death of Sand of God, post pics and video of how I Disassembled sand of god
i know now what is will be my backplate
coldzero.eu did a great job on this, they are on order now
these for 2 GTX 780 HOF
and this one for my Xonar Phoebus
SLI Bridge
