08-21-2018 04:20 AM
09-06-2018 08:02 PM
09-18-2018 01:43 AM
09-18-2018 10:19 AM
09-25-2018 03:36 AM
xeromist wrote:
Well, a bit late now but you could have printed a slot for the panel to slide into. Alternatively you could use some white U channel to hold the window.
09-25-2018 09:09 AM
thorkon wrote:
Its not too late :D. I can alway print/add to make something work. The window is really large so I can sacrifice some of that space if means getting a good door/mechanism on moving the window. I see what your saying on white u channel but would be a little hard to slide it out if I'm imagining the same setup as you with it.
10-24-2018 08:07 AM
01-15-2019 03:01 AM
