Bombproof Builders Desk.....Build
dieseldog49
Ok so I have been planning on building a new desk ever since me and my brother in law built me a new PC work bench (Pictured below)
Using Just 2x4's and some melamine we built a super sturdy bench for about $120 and I couldnt be happier with it. Since then I have been looking at my current work/play station with a little bit of disgust, its made up out of 3 seperate desks none of which are exactly the same height. Further more due to my affinity for eyefinity and large PC cases I am finding that my little work nook is getting more and more cramped and cluttered. Heres a pic of the space I am working with please excuse the mess.
So the new plan is to gut the whole thing and create a desk that wraps around the entire area Like so (sorry for the small paint image)
Then I am going to wrap the top of the desk with custom printed Mechwarrior themed vinyl using my wide format digital printer. So on to the construction phase. I have to give a ton of thanks to the two guys working with me (these or their online handles), Talster91 aka my old room mate and Dreyco Valentin who is my brother in law. With out them theres no way I could get these kind of projects done with the quality and speed we do together, We are also building Talster91 a new desk for the gaming rig I helped him build. So here is the start today, we are using birch plywood for the top and kiln dried 2x4's for the frame, using a overlapping design to interlock the tops and frames together. So today we ripped the plywood and tomorrow we will build the frames.
Dreyco
Talster91
Also this arrived today 😄
Day 2
Ok Most of today is dedicated to Talsters desk build Which is specced to be L60xW30 with a 30 inch height
For legs on both desks are a L shape made of two 2x4's screwed together gives great stuctural support.
85 REPLIES 85
Area_66
Level 11
I will put some bracing , this bench look a little bit weak......
dieseldog49
Yeah unfortunately I can only work on small block V8's with this desk, I am gonna have to take it to another level if I want to throw a 454 on there 😛 . In all seriousness though I have had over 700 pounds on it and it didn't even budge.
You can put 7000 pounds on those bench, lol
dieseldog49
Ok I am getting alot of pm's for a update so here is what I have so for in Sketchup (I switched from free CAD due to the huge amount of models available in sketchup) I will be using either a bench hinge or piano hinge (I am open to suggestions) The model is missing several components at the moment, I couldnt find the right fittings to go between the vid cards and I have no idea how to make tubing yet (still new with digital design stuff) I am using 7970's with EK blocks but that could change depending on parts sourcing ect... I am going to do the entire desk and then make the cad file available to anyone who wants it. The plan is to run a long loop to the radiator with enough flex for it to open or create a joint with 2 off valves and a quick disconnect in between. I am open to idea's for alternate whats to setup the WC loop or any suggestions in general, I want this to be as awesome as possible. I am also going to try to get sponsors for the next stage of the build so hopefully I can take this build up another knotch!
Feel free to post questions and critiques and thanks for all of the response guys!
Nice Job man, I wanna now how the end result will come out!
I am follwing this!
Greetz
nice work on your google sketchup images
and is see you have take good use from my desige from motherbord gpu and psu ❤️
so it seems i have done a good job
frisianbear2002
Thats gone be great looking when its all done.:cool:
l Asus Rampage 4 Extreme l intel 3930X@ 4800Mhz (1.45volt) 24/7 l Asus matrix GTX 580 l
16GB Team Xtreem DDR3 PC3-20800 2600MHz (11-11-11-28-1)
l Coolermaster Silentpro 1000w PSU l Revodrive3 ssd l WD Raptor 150Gb (10000rpm) l Corsair H100 wc with 4 Cougar Vortex fans l CM HAF 932 Avanced case l Acer X243H 24'' l Asus RT N66U Dark Knight l Logitech Z2300 speakers
In progress the custom build PC Samurai Warrior ''Miyamoto Musashi'' in Japanese ''宮本 武蔵'' made by Pascal
Giannis996
if i bring you materials will you make me 1? haha i love this desk + build !!!
Project Name: System Specs:
Motherboard: Asus Rampage IV Black Edition
Prossesor: Intel Core i7 4820k
Graphic Card: Asus GTX Titan x2
*Power Supply: Cooler Master V850
Ram: 32Gb Corsair Dominator Platinum 2133Mhz
Case: Corsair Obsidian 750D
SSD: 2x Samsung Evo 250Gb Raid 0
HDD: 2x Seagate Baraccuda 2TB
dieseldog49
damn near.
loli
That looks absolutely stunning - but I hope for your sake you never have to move house o.o
