Asus aura and add custom rgb led strip
MIFans
Hi every one
i have Asus B150i pro gaming aura/wifi
how can i connect rgb strip led to it and control by asus aura?
This mainboard has no RGB Header
7 REPLIES 7
MIFans
no one dont know any thing?!
Nate152
So I bought a strip of LEDs from Amazon and despite being listed at 5050, they had a 3.5mm female jack instead of the 4-pin connector needed for the Strix. Any tips on what to look for in a product listing to make sure I get the right type of LED strips?
https://cablemod.com/ has Asus LED strip's
SinisterDev85
Level 11
Another possibility would be a kit like this , https://smile.amazon.com/Tingkam-Waterproof-Flexible-Decoration-Controller/dp/B01DBINHWA/ref=sr_1_1?...
Im actually replacing the original kit i put in my rig with one of these, because the LED's strip i first purchased were meh. The black PCB matches most cases nicely.
I dont need the IR remote to control the LEDs in my case because the Alpha has RGB headers, however I can cut the strips to the length i need, attach them to the headers and control them with the Aura software, and then use the rest to light up my PC area, i.e under my desk and behind my monitor. A kit like this might be ideal for you, since your mobo doesnt have the RGB headers. You could control your entire RGB setup with a remote that has TONS of customization options. Its definitely an option.
ASUS ROG Z790 Apex Encore | i9 14900ks | | G. Skill Trident Z5 8000 | 2x WD SN850x 4gb | Asus Strix RTX 4080 OC| Asus ROG Thor 1200w | Windows 11 Pro
62784*
62785
I have the Maximus IX, so I can also connect the RGB strips to the motherboard, I ordered Cablemod RGB strips. Did you use the cable supplied with the motherboard to connect the strip to the motherboard?
I think I need a second cable like that for my second strip but I have no clue what too look for.*
Corsair 3500x
Corsair HX1200i
Asus ROG Maximus Z690 Extreme
Intel Core i9-12.900k
Corsair H150i Elite Elite LCD XT
Corsair DDR5 Dominator Platinum RGB 2x32GB 5600Mhz
Samsung 980 PRO 2TB M.2 SSD (2x)
ROG RTX3080-O10G-Gaming
Monitor 1: ASUS ROG Swift PG34WCDMC
Monitor 2: ROG Swift OLED PG27AQDM
ROG Strix Scope II 96 Wireless
ROG Spatha X
Windows 11
