AMD/ATI Super Build, with R9 290x Cooling Mods!
StayClassyROG
Hello everyone! I'm currently in the process of waiting for my components to arrive from Amazon, but I wanted to post up my build, and as I start the build I will update the thread accordingly.
Components:
Silicon:
Sapphire Radeon R9 290x 4gb GDDR5
Asus Crosshair V Formula-Z AM3+ AMD 990FX Sata 6Gb/s
AMD FX-9590 8-Core Black Edition
Peripheral Accessories:
Corsair RM Series 850 Watt ATX/EPS 80PLUS Gold-Certified Power Supply
Western Digital 2 TB 3.5-Inch WD Se SATA III 7200 RPM 64 MB Cache Bulk/OEM Enterprise Hard Drive
Crucial M500 240GB SATA SSD
Corsair Vengeance Blue 16 GB (4X4 GB) PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory Kit
NZXT Phantom 820
Cooling:
NZXT PNZXT Kraken X60 280mm CPU Cooler
NZXT Kraken X40 140mm CPU Cooler
Sigma Cool MKII GPU Cooler Mount for Water Cooling AIO's
Enzotech MOS-C1 Heatsinks (20)
Arctic Silver CMQ2-25G Ceramique 2 Tri-Linear Thermal Compound
Corsair Air Series SP120 High Performance Edition Twin Pack
Breakdown:
This machine will be used for mainly editing photos and videos, but also for mining altcoins while browsing the internet. However, I will also be selling the completed build, if it meets my specifications for stability and power. Mind you, I am an Intel/NVidia aficionado, but I grew up with AMD and Radeon cards, so this is more of a return to my roots. The first and primary focus of this rig will be stability. I want this machine to run solid and maintenance free in the event that I sell it, as my name will thereby be attached to its quality from that point on. However, I also wanted a level of performance that will leave me satisfied.
Breakdown:
My choice in selecting the FX-9590 was mainly because of it being superior to most Intel i7's in its price bracket, and also because of the capabilities of this processor in terms of clock speed and rarity. Many people do i7 builds which I find great, but not too satisfying. However, tuning an AMD processor is more fun for me. I guess that I want to make a build that is extremely uncommon.
I chose the Asus motherboard for obvious reasons; you will not find a better motherboard anywhere else.
The Radeon R9 290X was chosen because of it being the current GPU king. However, thermal problems with these cards has left a dark shadow over ATI, something which I find disheartening. However, it now means that there is a current challenge of extracting the best results possible from these cards through altering the cooling, and I will explain my theory and blueprint for the upgrade later in this thread.
The PSU was selected simply because of it being a Corsair PSU that was rated with the 80Plus Gold badge, and also because of the flat cables and modular nature of the wiring.
This part here gave me a lot of grief in choice, but I decided on the Western Digital 2TB SE hard drive because of it being an Enterprise hard drive. It has 5 platters with a 7200RPM hard drive speed, dual processors for data thoroughput maintenance (stable file transfer rates), and most of all, the StableTrac technology that WD has. I have plenty of experience with Hard Drives, as I am a DJ who burns through them at alarming rates due to things like head crashing, and vibration. But most of all, the data that I will be storing on this drive is extremely sensitive, and I need a drive that will function at peak ability for years to come.
As for my selection with my SSD, the Corsair M500 was a no brainer. First off, I don't care about what the fastest SSD is. Many builders and newbie computer guys want to be the "fastest" and then wonder why they have stability issues. The Corsair M500 is probably the best SSD on the market when you look at the sum of its parts. First off, the drive has capacitors that allow the drive to finish writing data from the cache to the drive in case you have a power failure, or a sudden shutdown. Secondly, it is the only drive with the kind of NAND maintenance that ensures that a dirty SSD doesn't lose speed. That alone puts it miles ahead of other drives. It also supports Bitlocker Encryption/Decryption on a hardware level, to prevent encryption from slowing down file transfer rates.
I chose the Corsair Vengeance Blue 16gb, but in 4 stick flavor simply because in my old workstation, 4 sticks of RAM gave me the absolute best stability in Premiere Pro for video rendering when the sticks were not EEC. I suspect that it's because the sticks don't have as much data per stick flowing to each of them, and the load is spread across all four, reducing the likelyhood of errors. Also, there are some problems with faster RAM that are not EEC, so I'm playing it conservative. But this is the only aspect of the system that I left open to expansion in a short term period.
The CM Storm Stryker is the only case I found that can accommodate all of the things I want to do, while looking relatively attractive. The handle is an amazingly great feature, as on the rare occasion, I may have to bring the workstation to shoot that requires some serious horsepower on site.
I chose the NZXT Kraken X60 simply because it offered better cooling than the Corsair alternatives, at an attractive price point. As for the X40, I chose that one for the GPU, but more on that later.
GPU Modification Game Plan- R9 290X
I'm going to combat cooling the 290X in a simple way. I was one of those guys who was about to get the Accelero III or the MK-26 or some other obnoxiously large cooling solution. Water cooling was an option for me, except that the maintenance on a water cooling system would mean that my potential market of buyers was now axed, as most people don't even know how to clean a normal computer, let alone maintain a water cooling PC. Also, the cost of assembling a watercooled PC was quite frightening, as I would go the quality route, and that alone would hurt the wallet.
I stumbled across the Sigma Cool MK2, which recently announced that it supports the R9 290x. This mount allows you to mount an AIO water cooled system onto the card, and makes the most sense. I can now keep the card from occupying more than 2 slots (The MK-26 solution can take up as many as 5 slots!), and hit way cooler temperatures than air cooled solutions. All for a few dollars more.
The action plan will be to mount the X40 to the 290x, and then use Enzotech MOS-C1 heatsinks mounted to all of the VRM's to keep those cool. Their smaller profile means that each VRM will have it's own heatsink, which will result in cooler performance, but the height of the copper rods that make up the heatsink will aid in pulling heat out of the VRM. I'll use the Corsair SP120 fans in place of some of the case fans that have filters in the way, and use the case supplied fans to blow air directly onto the GPU to keep the RAM and VRM's cool. The RAM modules on the card will have Kootek copper sinks on them, mainly because they are low profile, copper, and designed for the Pi, but fit RAM modules.
I will be updating this thread with pictures throughout the build, so make sure to subscribe to the thread.
For those of you with R9 290/290x cards, you should definitely subscribe, as I will be providing before and after thermal measurements/comparisons.
**THERMAL COMPARISONS R9 290x**
Unfortunately, during a reinstallation of Windows 8 due to a power failure that somehow borked my first installation (PSU wasn't up to snuff), I lost most of my screenshots of the R9 290x temperatures when it was still on air. However, I did write them down.
290x (air): 98 degrees Celsius 100% load @ 10 minutes
290x (air): 41 degrees Celsius idle load
290x (air): 700-980mhz core (<20 minutes full load)
290x (water): 70 degrees Celsius 100% load @ 15 minutes
290x (water): 34 degrees Celsius idle load
290x (water): 1100mhz core (<20 minutes full load)
320573205832056
17 REPLIES 17
Antronman wrote:
Firepro W8000 and W9000 GPUs.
is workstation cards for use whit autocad and graphic work.
and its not for videogames at all.
the w8 and w9 is 1.5 years old and overpriced cards for the industry.
http://hothardware.com/Reviews/AMDs-New-FirePro-W8000-W9000-Challenge-Nvidias-Quadro/?page=1
Antronman wrote:
If this is a super build, why is it using the R9 290x? It should have an HD 7990 or a Firepro W9000. The GTX Titan and 780Ti outclass the 290x. But the HD 7990 outclasses those two, as do the Firepro W8000 and W9000 GPUs.
Hey there Antronman!
The reason why I chose not to use Firepro cards is simply because they offer diminishing returns for their price, and they are limited as to what the can do. The R9 290x, as far as video and photo editing is concerned, is more than overkill because it can be enabled for OpenCL computing by simply adding the name of the card to the list of supported GPU's in Adobe's software suite. Also, by choosing the R9 290x, I have a card that is adept at gaming. The HD 7990 last time I checked was not able to match the R9 290x when it is properly cooled. The GTX Titan is also twice the price for the same performance, if you OC the 290x. Mine is currently at 1100mhz core clock, and 1300mhz memory clock speed, and it is rock solid.
abvolt
Level 11
looking good dude love the 290x
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Thanks mate 🙂
Antronman
I never said Titan. Even with the stock cooler, the GTX 780 Ti and the R9 290x outdo the GTX Titan in benchmarks. And I'm sorry, but last I checked a WC HD 7990 overclocked outdoes an R9 290x.
Say hi to the next generation.
Peace is a lie, there is only Passion
Through passion, I gain strength
Through strength, I gain victory
Through victory, my chains are broken
The Republic of Gamers shall free me
Hmm I did some more research into the matter, and while the HD 7990 is definitely more powerful, it's because it has 2 gpu's on one chip.
However, the R9 290x does have a 512 bit bus, whereas the HD 7990 is at a 384 bit bus, which two processors share. I cannot quote on real-world performance in terms of the performance of the 7990, but I do know that the bus speed is really important for me, due to the bandwidth that simultaneous 4k editing streams can demolish. The 290x is still impressing me as to how well it can manage video editing, and I used to have an Nvidia 660. When Adobe/OpenCL support improves, I am sure I'll see even more performance gains simply because of that bus.
Gaming wise, not that big of a deal and the 7990 is no slouch by no means, but the minute you venture into video editing, that bus speed makes a world of a difference, from what I've learned.
LukeeVassallo
I have one question, do the copper heatsinks provide sufficient cooling for the memory chips on the GPU ?
| Maximus V Formula | i7-3770k | 16Gb Dominator Platinum | GTX 780 | Force 240Gb | 2TB Caviar Green | Obsidian 650D | AX850 | H100 | 24" LED VS247H |
They do, but my case has a 240mm fan that blows towards the PCI-E slots so that might help my numbers; I'm running a 1400mhz clock stable right now and I left it on furmark all night with no problem so I'd say that the heatsinks should be fine 🙂
