They never fixed the problem with Aura Creator and Claymore I
ArchLaLo
Good to all, I wanted to know if this problem was left in nothing, it's been more than a year and I don't see that they have solved it.
Problem: When I use the Aura Creator it is not possible to customize the ROG logo, it does not light up, if I disable aura sync and only use the asus crate it works perfectly, the problem is that I cannot customize it to my liking.
If someone can tell me that they could solve it with something or that they found the version of the aura creator when it worked correctly
Greetings.
PS: I'm using a translator, I speak Spanish
Lightbringer
Hello,
giving this one a BUMP. I am experiencing the same Problem.
bump
same problem for me:mad:
Asuslover888
Greetings.
any update??
was it solved?:confused::confused:
