Aurora Blacklight Preset for ARGB (will function with RGB also) [Upd. 1420-UTC]
mmck617
Pink Rose and blacklight blend on the Mainboard, and Deep Purple Blacklight with short cycles (x2) on 1x ADD Header to display blacklight, to Aurora Borealis type mix of color range, to Primary blacklight.
files below were updated at 1420-UTC
Asus ROG Strix Z370 Mainboard and ThermalTake TH120 ARGB Sync Snow Edition CPU AIO Cooler, Corsair Vengeance RGB Pro 32GB (2x16GB)
RAM Not Aura Controlled.
[img]https://i.imgur.com/n6sS9aQ.jpg[/img]
[img]https://i.imgur.com/O4LvQiw.jpg[/img]
2 ACCEPTED SOLUTIONS
Accepted Solutions
mmck617
Updated to 2.0: better overall mix of colors and more blaklight; Checked entire playlist for errors more than 3 times.
zipped .xml so Google Drive can scan before download. Extract or copy/ paste from .zip to folder of choice, or desktop, Import from that location.
Aurora Blacklight 2.0: https://drive.google.com/file/d/1MFLluBWL6jVJdeQ3AnZpQ-uoVJtgynHT/view?usp=share_link
Yes, please refer to this tutorial, to assign the effects to your components and devices:
https://youtu.be/7qSyFT-WSRQ
How i can make exported .xml files in Aura Creator and how End Users can modify and adapt the presets to devices and components.
9 REPLIES 9
mmck617
Updated the .xml's (Audio Volume Beat Box, and Frequency on Audio Spectrum. Both presets respond to audio in sky blue.) Blacklight Activation Tide sweep at near vertical angle after [middle] of 2 unique short cycles.
Aurora Blacklight : 2x short cycles of deep purple blacklight and pink ARGB swirls pattern and short color cycle of blue, cyan and purple, to Deep Purple blacklight again on the ADD Header.  Pink and blacklight waves on Mainboard. Audio responds in sky blue (Frequency Response).
Aurora Blacklight (Music Volume): 2x short cycles of deep purple blacklight and pink ARGB swirls pattern and short color cycle of blue, cyan and purple, to Deep Purple blacklight again on the ADD Header.  Pink and blacklight waves on Mainboard. Audio responds in sky blue (Beat Box Volume). RAM Not Aura Controlled.
Links Deleted.
mmck617
mmck617
[Deleted]
Matrix Aura Armory Crate Preset (White represents the black void for the Matrix.)
MATRIX Remastered ... 3.0
https://drive.google.com/file/d/1U1VsRQZxOwKIn8V8tSs6L7aEWf3jvJzv/view?usp=sharing
Matrix with ROG Icon (Customizable, some aliasing there.) [img]https://i.imgur.com/rOurJgO.jpg[/img]
Updated the Matrix Aura loop so that none of the strobing is chaotic, it's still looking intense, it's just not overkill.
danieljose
my side lights are not working, any help, tried armour crate on off and restart etc
