Ryujin OLED temperature delta vs. CPU sensor?
DavyDee
Hi all,
been noticing a gap of about 5°C lower temps between the OLED display on Ryujin and the actual? HW sensor read out from various utilities.
Does the display/LiveDash not use the actual CPU temperature sensor, or what is the issue here?
Anyone seeing the same or having an explanation for this?
Thx
Davy
DavyDee
PS: Never mind, found the answer, described in this review of the Ryujin 360.
The readings are delayed, and also taken from a different sensor, so no wonder.
To whom it may concern: https://play3r.net/reviews/cooling/the-best-360mm-aio-cpu-coolers-2019-360mm-shoot-out/
