need help: gtx 1080 strix & pwm external fans in GPU Tweak?
duenor
I have two noctua pwm 140mms connected to both pwm headers on my gtx 1080 strix. however, they don't turn on unless the card hits 60c. I understand why that's the default, but I want it to turn them on at 50c. Unfortunately, gpu tweak won't allow me to slide the control bar past the default 60c at all. its either 60c or higher.
all i want to gpu tweak to do is 1) turn on my 140mms @ 50c consistently 2) load that settings change and my rgb profile in aura at windows start without any action from me.
Is there any way to do this? I was able to do this in an earlier version of gpu tweak, but that version wouldn't save my profile settings properly.
I'm using the latest version of gpu tweak.
chickentail
Hi there.
I am having the same issue with my 1060 STRIX.
Added to that, when I choose "Fan Auto Calibration" it fails about 80% of the way with the output "Detect Fail!" and no reason.
@Bahz and the Asus guys, could you shed some light on our situation please?
Thanks
