FanXpert3 : able to control rpm according to water temp ?
White_Wind
I will be watercooling my system and I wonder, if I plug a temperature probe into the mobo thermal connector ( VII Hero ) and put the probe in the water in my reservoir, would FanXpert3 be able to automatically control the rpm of my rad fans in regard of the temperature of the water ?
The four fans are Yate Loon D22BL-12H, 220mm non-PWM, set on a big external radiator.
zoomee
Not sure if the FanXpert3 software will allow you to do it mate but I'd highly recommend an Aquero 5 or 6 unit 😉 -especially for them non-pwm fans
1700X B350/RX570 STRIX
