Fan Expert 3 system temps
bitman
I have a few questions if anyone is using the new Maximus Vll Hero z97 motherboard, I understand that Asus as updated the Fan Expert to be able to control the system fan Pwm connectors each separately but I would like to know which system temperatures can you assign to the fans. I looked at the manual and all I see is it can be set to CPU,System temp or the one Temp sensor that is on the board! Only ONE temp sensor input you have to be kidding me! Should I buy the Vii Hero or is Asus going to make a Maximus Vll extreme if they are I will wait to buy it instead
0 REPLIES 0
