Aura RGB LED problem
bixsi
hello,
very annoying
what is the problem ?please help me,
I am using asus aura lighting control but an old version.
there was no such problem before
17 REPLIES 17
bixsi wrote:
I have updated my bios, but the problem still persists.
Is this a card or LED fault??
Is it an aura software error???
Can you tell me more about the LED effect that you have on the graphics card.
1. Does the color of the LED change following the effects you are applying?
2. From the picture it seems you are having problem with the ROG eye mainly. Can you confirm and give additional details.
And don't forget, Keep pushing it !
Rog eye logo is different, republic of gamers the writing gives different light.
they are not switching in the same color
Is the card's LEDs corrupted? 😞
Does the ROG Eye LED, are getting a RED, Green or blue color normaly -> Please take a picture while you are applying this effect.
AkaNe@Asus wrote:
Does the ROG Eye LED, are getting a RED, Green or blue color normaly?
The problem is just that the Republic of Gamers and ROG eye aren't sync?
Could you take a screenshot of your AURA for graphics card software? I am trying to replicate the problem, but so far the VGA LEDs are in sync.
Rog eye green red blue color yes, but I can not get a white color.
Yes,Republic of Gamers ve ROG eye not synchronized.
Thank you very much for your interest.
https://hizliresim.com/WG8dML[/url
Can you try in Static mode.
-> Red color in Static mode
-> Green color in Static mode
-> Blue color in Static mode
Then take a picture of your graphics card when applying each of those settings.
AkaNe@Asus wrote:
It can sometime impact the overall sync. Always better to have the latest BIOS and drivers.
Which motherboard do you have, and what is the model of your graphics card?
Do I need to update my video card bios?
Gofran
is this issue resolved ?? so what did you do because i have it also 1080ti strix z270 ix formula
The guy above seems to be using Aura AND the striped version that comes with the GPU.
Better not to mix them imho. So turn it off in the striped version and control the lightning only with Aura and see if it works.
