ASUS Aura ISSUE fix for no compatiable devices.
Sgt_rjm_13_b
Greetings,
ASUS AURA no compatible devices found issue???
Maybe this could be a sticky maybe it will help someone else.
So after downloading the lighting control app, extracting and installing, you get a no compatiable devices found error. What to do next? I will share what worked for me.
Before extracting the file, you must right click and check the unblock option on bottom right in the properties screen. Then once extracted open the unblocked extracted file and double click the asus setup and let it run, then reboot. When you open it this time it should see your rgb devices and allow you to control the speed and colors etc
I have shared a little video on how to do this. I wanted to recreate the issue but now that it has been installed once correctly it will not reproduce the no compatiable device. My issue was with brand new build first time installing aura.
https://youtu.be/3lG9-fsNicw
18 REPLIES 18
BillBittel
Level 12
I am sorry you are going through this, especially with a Max XI board. I do not see that you tried re-flashing the BIOS. I would try that, or as last resort - re-flash the Aura chip. I guess you could RMA the board but I imagine you do not want to do that, and there is no guarantee that the problem is the board.
Another idea - I looked through your posts and see that you are using Themaltake Riing Plus Fans with the Thermaltake TT Sync controller. I don't know anything about those products but maybe that is what is screwing things up. I assume the TT fans or controller have to plug into an Aura header for Aura to control them. You could try disconnecting the TT fan LED connections and see if you can get the board, RAM and GPU to show up in v1.07.22.
Yes I am using Thermaltake Riing Plus fans however disconnecting them does not help sadly. I eventually reverted to version 1.06.17 BUT it only shows my motherboard and ram, it does not show the addressable header (Thermaltake fans) or my GPU. Now when I try a later version of the software, I have tried several, only my GPU shows up, I guess it is better than nothing showing up but this software really seems to have serious issues especially with my new board.
As an aside I have just updated to the latest bios (0602) and nothing has changed.
BillBittel
Level 12
Update - PWNSENSEI, who has been fighting the exact same problem posted this solution. I have not tried this but if you are stuck and BEFORE you try re-flashing the Aura chip, try this.
Found a solution:
>Uninstall
>Reboot
>Run Aura Cleaner
>Navigate explorer to extracted Aura folder installer (Lighting_Control_1.07.22\LightingService\aac) and run each executable inside of the folder, uninstall all of them when prompted.
>Cleanup Registry with Ccleaner
>Reboot
>Install Aura
>Reboot
Now it should work.
If it doesn't it means the installer fails to install all the modules within the "aac" directory we have navigated to before. In that case, run each of those executables once again and restart Aura.
I urge Asus to fix the uninstall process of their Aura software as well as their Ai Suite software. Updating or solving problems is a real pain in the ass for experienced users, imagine how awful it must be for most users who don't even know how to get around
https://rog.asus.com/forum/showthread.php?101543-SOFTWARE-AURA-Sync-RGB/page28#post742107
Found a solution:
>Uninstall
>Reboot
>Run Aura Cleaner
>Reboot
>Install Aura
>Reboot
Now it should work.
At long last !!!!! a solution that worked for me. By individually running each needed executable in the "aac" directory I finally after 3 reboots got my Motherboard, RAM, addressable leds and GPU to show up and can control them all. THANK YOU !!!!!!
asus doesn't remove this after uninstalls...
and also it didn't add the corsair there so i manually added it rebooted and it worked.
You're welcome, my boy.
After following all these steps, I'm still getting the same issue.
Anything else I can try? I also had to run through these steps to even get Aura to launch because Windows 10 was blocking it: https://mynuuo.zendesk.com/hc/en-us/articles/360000764413-How-to-disable-UAC-for-a-specific-program
I did update the BIOS on my Vega 64 a while back, but I'm not sure if this would cause an issue?
Is this works to you ?
BigJohnny
@ OP, your solution seems to be limited to you and AV software you run.
Aura has time and again posed problems, even after its installed.
Best way to get it installed is on first go right click and run as administrator. If its a second go uninstall the old, delete the install folder that gets left behind then run Ccleaner to remove orphaned registry entries, reboot, install, reboot then set up. Only thing more problematic is AI Suite. ASUS makes some good hardware but their software team needs some fresh talent as the same problems have been plaguing them since the inception. If they were a stand alone entity they would have went under long ago.
