AI Suite 3 is messing with my display sleep time and system sleep time
Quiller101
I noticed that AiSuite changes my power options on certain intervals when I set my display sleep timer (5 minutes) and system sleep timer (never). AI Suite 3 changes it to the AI Suite Power Saving Formula that's active.
So when the power saving formula is "high performance", the display sleep timer becomes 1 hour and the system sleep timer becomes 2 hours. When the power saving formula is set to "max power saving the display sleep timer becomes 30 minutes and the system sleep timer becomes 1 hour.
It took me some time to find that AI Suite 3 is causing this "bug/feature", but I would like to know how I can change the sleep timers in AI Suite, so that it doesn't change the values that I want.
I'm uising windows 8.1, but I assume that this also happens on other windows versions.
25 REPLIES 25
HiVizMan
Level 40
Which other AIsuite features do you use?
Quiller101
I primarely use AI suite for the fan profiles, but I also use it to keep an eye on the system temps and voltages.
HiVizMan
Level 40
So the fan profiles are changing your OS power plan? I think I am not quite understanding so please forgive me.
I have just done some fan profile changes and my OS power plan did not change.
Quiller101
You asked me which other features I used. What I use AI suite for isn't causing the changes in my windows 8.1 power options.
On the main window of AI Suite you can choose between 4 Power Saving Formulas: Auto, High Performance, Max Power Savings and Away Mode. Those formulas are causing the change in my windows power plan.
So when I put my display sleep timer manually on 5 minutes and disable my system sleep timer, AI Suite will change those two settings in my windows power plan according to the Power Savings Formula in AI Suite.
Quiller101
screenshot of AI Suite
32076
and here is the screen shot of the values that AI Suite's power savings formula changes (High performance and Max Power Savings)
32077
Screenshot taking after selecting Max Power Savings
32078
Selecting Hig performance will change the timers into 1 hour for my display and 2 hours for the system sleep timer.
HiVizMan
Level 40
Ah I get it right I understand now.
That is correct AIsuite will override the default OS settings, and of course will override your manually set options too. That is how it is designed to work when you select a particular mode.
Quiller101
Hmmmm. I fail to see what my display sleep timer has to do with my system performance.
Maybe that in the next version of AI Suite that can be changed, since it makes no sense to me. Changing the power formula in AI Suite has no effect on the power consumption of the cpu. I would expect that to change rather than the display sleep timer.
Anyway, thx for your answer.
HiVizMan
Level 40
I must agree with you that it does not make sense and will pass on the suggestion.
robertprowan
I have the exact same issue and it's very annoying. I don't want my computer to sleep because I'm running VMs on top of my Windows 8 PC. The best I can do is set it to 5 hours in AI Suite III.
An obvious fix is to remove AI Suite III but I really like the fan profiles. It's better than Speedfan I used previously.
I wish Asus would fix this by disabling the override or having a "never sleep" at the end of the slider!!
