My Problem with the Ai Suite 3 on my Maximus VI Extreme is that it is not loading my Custom Fan Settings on Boot Up or after Standby/ Monitor Shut off.
My CPU Cooler is a Noctua NH-D14 2011 with 1150 Bracket.
The fans on the cooler run with the Standart Asus Ai Suite at 200rpm that's the least minimum on these Fans apparently(Ai Sute Bench). My Custom Profile loads them at 600rpm, but i allways have to manually load it, Ai Suite just can't remember my Fan Settings. I always need after Windows Login to manually Start Ai Suite and load my Custom Profile. Is there any way to change this?
