Z490-P: Can't control LED ?
Dodoz
Hello, I know many people had the same issue but I didn't found any solution.
It's my very first heavy computer, so I wasn't very aware that some parts were having controlled LED.
The default color of the led seems to be a Orange-ish light that fade but after trying to figure out how I can control it, it seems I can't (despite being Aura Sync RBG compatible).
I have installed Icue for my RAM (wich is working) and it detect the Motherboard as an entry, but it doesn't do anything.
I tried ArmoryCrate and I noticed some weird things:
- Sometimes motherboard appears but can't load every indicator (fans speed, temp°, ..)
- Sometimes it doesn't appear at all and I get an error/or appear after a long search
- When the widget worked I could change the fan's speed, but directly in AC it doesn't react.
- On boot, after windows finished loading an error appears telling me a file is missing.
89026
I tried to uninstall ArmoryCrate and Reinstall it, but didn't changed much, it's still broken.
Do you have any ideas ?
0 REPLIES 0
