(ver 5.8.8.0) Panel Overdrive option not working properly on Flow x13
SnailyKid
Hi I'm using Flow x13 2023 (GV302XV).
After recent update to 5.8.8.0 from microsoft store, the panel overdrive option seems gone.
see below (there were 5 tabs before)
However, weird enough, the overdrive seems to be always on no matter pluged or unpluged.
I've tried installing refreshrateservice from other laptop driver page. The option is back, but I cant turn the overdrive off (like after I click the tab and close amoury crate, then re-open, the tab is still on), no matter on battery or on plug power.
Tried reinstalling Amoury Crate several times and it still not shows up. Is there any fix to it or did I screw anything?
16 REPLIES 16
MasterC
Community Admin
Community Admin
Resolved in ASUS Smart Display Control v2.10.24
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
Hi, I have the same problem but I cant find where to update ASUS Smart Display Control v2.10.24 and MyAsus did not find any updates for it either.
Which laptop do you have?
Hi, I have an Asus Rog Zephyrus Duo 16 (2022), model GX650RS
The update hasn't reached you yet, but here you go. You may install the update manually.
Unzip and run the batch file (ASUSSmartDisplayControl.bat) as administrator (right-click on file).
Upon completion, the command prompt will disappear. Reboot system and check if resolved.
Hi, thank you very much, I've installed the update and the problem was solved
