(ver 5.8.8.0) Panel Overdrive option not working properly on Flow x13
SnailyKid
Hi I'm using Flow x13 2023 (GV302XV).
After recent update to 5.8.8.0 from microsoft store, the panel overdrive option seems gone.
see below (there were 5 tabs before)
However, weird enough, the overdrive seems to be always on no matter pluged or unpluged.
I've tried installing refreshrateservice from other laptop driver page. The option is back, but I cant turn the overdrive off (like after I click the tab and close amoury crate, then re-open, the tab is still on), no matter on battery or on plug power.
Tried reinstalling Amoury Crate several times and it still not shows up. Is there any fix to it or did I screw anything?
1 ACCEPTED SOLUTION
Accepted Solutions
MasterC
Community Admin
Community Admin
Resolved in ASUS Smart Display Control v2.10.24
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
16 REPLIES 16
OptimusPrime1
ASUS TUF Gaming A15 AMD Ryzen 7 6800H 16GB 1TB SSD GeForce RTX 3070 15.6 Inch Windows 11 Gaming Laptop - panel overdrive missing from Armoury create after 5.8.8.0 update, same issue as original poster.
studio102
Same problem here. Asus TUF Gaming A17 AMD Ryzen 9 7940HS
studio102
Possible to share the file for refreshsateservice?
I downloaded from G14 official page, but pay attention
Panel Overdrive does come back after installing but may not work properly on other devices.
I guess it is because the panel overdrive is now not controled by this service for some system ( such as Flow x13, the service was not pre-installed and still has panel overdrive originally
https://dlcdnets.asus.com/pub/ASUS/GamingNB/Image/Software/SoftwareandUtility/13907/RefreshRateServi...
SnailyKid
The most annoying thing is that even I've tried uninstalled Amoury Crate using uninstall tool and reinstall older version, the option never comes back. Seems 5.8.8.0 killed something or changed how this function works?
I hope there is a fix in next update.
Rammouz
Same here! Asus G18 - BIOS 325. Armoury Crate 5.8.9.0. They confirmed that it's caused by a Windows update (who owns how or why) in late March and they'll be fixing it shortly.
ASUS G18 - RTX 4080 - 32GB DDR5 5600 MHZ - I9-13980HX.
 It seems to have caused the refreshrateserverie can't start。
Zylon_
So has it been fixed or not?
Looks like it hasn't been repaired yet
