switch between lighting on and off with one click or shortcut ???
wartu
Hello, is it possible to turn off the lighting with a click or a shortcut?
I would like to switch between lighting on and off with one click???
THX for Help
4 REPLIES 4
Nate152
Hello wartu
I suppose it could depend on the device.
I can turn the lighting on and off in one click with the ROG Azoth in Armoury Crate.
wartu
I'm looking for a solution without opening the ArmoryCrate software (for all devices together at once)
Assign a key on the keyboard or mouse? or desktop Shortcut?
Nate152
I don't think this is possible without Armoury Crate.
If using a keyboard, you can press Fn + the up and down arrow keys.
If you have multiple devices connected and synced with Aura Sync, you can click Dark (Off), this will turn off all lighting for your devices.
wartu
It's a shame that such an important function is not supported???
I have now created a profile that switches everything off when the “Core Temp” program is opened!
It works but it's not the same... Is there anybody with other ideas? how to solve this?
