Ryujin III - Not loading in Armoury Crate (Not loading settings for Internal Fan for VRM) S-1002
nllelobr
Hello guys!
I noticed recently the FAN inside the AIO block for VRM (the small one) was running in a constant speed (high) and making a annoying noise.
I tried to check the device settings in Armoury Crate and I can't load the device page (looks like it is not communicating with the hardware.)
See photo attached with error.
The only way to fix it is uninstall and install again. it holds for 1 day (or maybe one cycle of turn off and turn on) and the issue is back.
Any ideas what it could be and how to solve?
Thanks
(PS: Posting here since there is no official AC Topic for new version and the one still visible it is locked.)
Item Version
Armoury Crate UWP App 5.9.13.0
ROG Live Service 2.4.26.0
Aura Service (Lighting Service) 3.07.54
Armoury Crate lite service 5.9.13
Aura Wallpaper Service Not installed
Aura SDK 3.04.46
ArmouryDevice 4.2.0.4
ASUS AIOFan HAL 1.4.2.0
ASUS AURA Extension Card HAL 1.1.0.20
ASUS AURA Motherboard HAL 1.5.0.2
ASUS Ambient HAL 4.2.0.0
ASUS Keyboard HAL 1.2.97.0
ASUS Mouse HAL 1.2.1.9
AacAudioHal 1.3.83.0
AacDisplay 1.2.39
AacVGA 0.0.7.0
KingstonDram 1.1.36
AURA DRAM Component 1.1.27
ENE RGB HAL 1.1.53.0
ENE_EHD_M2_HAL 1.0.13.0
Patriot Viper DRAM RGB 1.0.9.8
Patriot Viper M2 SSD RGB 1.1.0.3
Universal Holtek RGB DRAM 1.0.0.7
WD_BLACK AN1500 1.0.14.0
AIOFanSDK 3.00.25
AIOFanSDKPlugin 2.00.02
AiSuiteSDK 1.02.18
AudioSDK 3.01.33
KeyboardSDK 3.00.85
MainSDK 2.01.34
MbLedSDK 3.00.40
MouseSDK 3.01.43
UnifyDongleSDK 1.00.09
VgaSDK 1.00.21
Armoury Crate Plugin - Aio 2.0.20
Armoury Crate Plugin - Headset 1.2.22
Armoury Crate Plugin - Keyboard 1.3.12
Armoury Crate Plugin - Motherboard 1.2.22
Armoury Crate Plugin - Mouse 2.3.3
Armoury Crate Plugin - ROG FAN XPERT 4 2.0.12
Armoury Crate Plugin - UnifyDongle 0.1.1
Armoury Crate Plugin - Vga 1.0.4
ASUS Motherboard 4.04.03
ROG CHAKRAM X 4.05.23
ROG CHAKRAM X BLE 4.05.23
ROG CHAKRAM X WIRELESS 4.05.23
ROG DELTA II (2.4GHz) 4.03.31
ROG DELTA II (Bluetooth) 4.03.31
ROG DELTA II (LE Audio) 4.03.31
ROG FAN XPERT 4 4.02.04
ROG OMNI RECEIVER 4.02.02
ROG RYUJIN III 4.01.31
ROG STRIX SCOPE II 96 WIRELESS 4.03.55
ROG STRIX SCOPE II 96 WIRELESS (2.4GHz) 4.03.55
ROG STRIX SCOPE II 96 WIRELESS (BLE) 4.03.55
VGA 3.01.05
1 ACCEPTED SOLUTION
Accepted Solutions
Thank you for sharing your Exp. here.
Before I tried your advice, I noticed one weird behavior with the settings I was saving and restoring.
So I started tothink it could be a corrupted settings.
Tried to re-install and update ALL without restoring settings.
BBbbboooooommmmmmm it is working again. The issue is gone.
The weird behavior I found on the settings in the Ryujin tab, was couple of ghost GIFs, that I was able to notice before the issue started.
4 REPLIES 4
nllelobr
More info about it.
Now the AIO works for 2 sec, freeze the gif, turnoff and you can hear the fans speeding for half second and off.
Also when this happens the Ryujin disappear from device list and comes back.
PS: I turned on volume, and it make the sound of new device connected and disconnected. and keep this in a loop.
I tried updating only the AC version, and no SDKs for any device, issue persist,
Tried to not update the AC, only the devices itself, issue persist.
I'll try now to not update anything. See how it goes.
Kvakunoff
I had the same problem. The problem was in the USB port on the motherboard. try another port or disable intel xhci mode in the bios. Go to Advance > Devices > USB. Find xHCI mode and select Disable. If everything works normally, turn it back on.
This forum is dead, even if someone knows how to help, they don't post. Nobody bothers.
I've asked for help before, they just look but nobody answers.
I hope I helped you.
Thanks to share your exp. Kvakunoff.
I did some new attempts.
If I do another AC install, and DON'T update the AC and any other SDK, the issue do not happen.
Other thing that I skipped, was to restore my settings.
I have the sus. the settings is broken.
I'll try to update everything without the restore settings. If the issue is back, I'll try to change the USB port in the motherboard. (or the settings in BIOS like you informed.)
I'll be back here with my finds.
