ROG Fan Controller Temp Sensor Issue
YazidOlayan
Hi
I have a Z790 maximus extreme and i have attached all my fans to the ROG fan Controller that came with the motherboard
but in armory crate the temp sensor for the CPU Package indicate (0)
see the attach photo
96412
which mean all my case fan rpm are not going to be adjusted automatically since there is no reading at all
is there any way to fix this issue?
and btw I have noticed that the temp sensor for my ryujin 2 AIO is CPU which is a way off by almost 10 degrees compared to CPU Package temp
96413
is there any way to change it to CPU Package?
YazidOlayan
so, I have actually managed to get the reading for the CPU package for the fan controller
BUT
It's not accurate att all and i believe it's counting on the motherboard temperature instead of the CPU package
even though is saying CPU Package
96444
96446
and here is another reading
96445
96447
and this really not good at all as it's actually affect my case air flow
ASUS, Please Fix This
Manjiiii
as I find older and older threads about this problem.. I'll just go forward and deactivate fanxpert and go with a different program... this RGB and fan issue in 2023 is just exceptional
