problems installing Armory Crate
rey123
Are the servers down or what? I just reinstalled the PC and I can't install Armoury, it keeps looping saying there is no connection, I reinstalled Windows again to see and the same error continuesCaptura de pantalla 2025-01-02 200309.jpgCaptura de pantalla 2025-01-02 200333.jpg
16 REPLIES 16
Nate152
Hello rey123
What version are you installing?
Try installing version 3.2.11.2 - Armoury Crate - Support
the latest version. and it is a problem that it does not connect to your server, no internet or firewall or anything etc, I have been using this for 5 years with my asus pc, in addition to the fact that I have tried other versions of win11 just in case and the same error continues
DHGx1v7
İ just reistalled windows and Im getting same error. I tried version3.2.11.2 too but its not working as I expected. I also tried closing antivirus, checking bios and etc. but like I said non of these worked. Is this is a common error or not ?
rey123
@Nate152
If it weren't for the fact that this app unlocks all the power of the PC, I wouldn't even install it, so why can you search for information about the problem?
elmureato
i have the same problem. i uninstalled amoury crate and wanted to reinstall it. it doesn´t work. same error. no internet connection. but internet is there. Asus please fix it
elmureato
MFBTH
Got the same problem here.
Same issue for me. I can't even use my keyboard now! Must be an issue with their servers
dayzproplay345
Same thing happening to me rn it keep looping back and forth those lines also I'm using rig ally z1e also
