03-30-2020 06:02 AM
03-30-2020 07:35 AM
Archmaxy wrote:
Hi all,
I have attached this Youtube link: ....
Here you can see ....
03-30-2020 07:48 AM
revealed wrote:
No, it is set to private.
I have the same board. Did you try out the effects in Aura sync which is the one you want to have? I asume it is rainbow without watching your video. Normally it should help if you simply hit that triangle symbol in the Armoury Crate software and select rainbow then?
Ah yea seems you would need to uninstall aura sync and switch to the Armoury Crate instead to have the things i talked about even. This has sort of integrated Aura Sync, not the old fashioned it seems. I don't get it properly too. But as far as i understand Armoury Crate is supposed to sort of superseed the old fashioned Aura Sync standalone?
03-30-2020 10:29 PM
03-31-2020 04:47 PM
Archmaxy wrote:
So turned out I already had Armoury Crate. I used it and the effect is now better, but still different from when I boot up my pc.
As it's now, when idling, it has the better rainbow effect, but it seems like the lights are much wider then when it's booting up. It's almost like when booting up, there are less lights at a time displaying a single color, so the rainbow effect is much more colours at the same time and seem more intense.
Do you understand what I mean? So it's better now, but it needs to get even better.
12-06-2020 05:41 AM
Archmaxy wrote:
Hi all,
So I am proud to own an Asus ROG STRIX Z390-F GAMING motherboard with all the the lovely RGB options. I am using a Sharkoon ELITE SHARK CA200M case, which has an RGB compatible fan at the back and 2 beautiful "matte" rgb stripes at the front.
I am experiencing a problem however.
Whenever I boot up my pc, the color scheme on the RGB lighting is different. I boot up my pc, it starts the rgb in the lovely colors, but when I come to my login screen, it changes the color scheme to something I do not want. I don't know how to get it work like I want. I have been experiencing this problem for a short while now, not since I bought my pc.
I have attached this Youtube link: https://youtu.be/BQAYTTzz_bA
Here you can see what happens when it starts up and when I get to the login screen.
What I want, is the beautiful rainbow-like stuff happening at the beginning, not the slow dual-color cycle that keeps happening. Asus AURA Sync doesn't seem to fix my problem.
Thanks in advance everyone!
03-04-2021 03:01 PM
piotrl wrote:
I have the same error on Z370-F gaming. Did you fix it?
03-10-2021 02:32 AM
03-11-2021 07:53 AM
dianaminter93 wrote:
I think it is by default there is nothing to be done, i noticed this when i was playing some racing games, all of a sudden it starting generating weird color pattern.
03-14-2021 07:57 PM
Alan wrote:
Thanks for your response and especially for registering on these forums to do that.
I've figured out a work around but I have no idea how this has caused it's result:
I upgraded the BIOS version and since then, instead of being static red, it gives the rainbow effect when booting. I still can't change it but I'm just glad it's better than red :). Hope that works for you and other people if they get the same issue.
