01-11-2022 12:52 PM - last edited 3 weeks ago by ROGBot
01-11-2022 01:12 PM
01-11-2022 02:20 PM
01-11-2022 02:15 PM
PitViper wrote:
I get a loading screen that goes on forever and a message pops up behind the loading wheel and I can't read what it says because it's blurry, and can't click on it because the loading wheel is in front of it. I has a button on it that looks like OK but I just can't click it. This happened after a firmware update to the head set. Used the uninstall tool and reinstalled but no luck. Just got the Theta 7.1 now I can't change the sound settings, otherwise they work fine. Armoury Crate is detecting them and every thing looks fine in the device manager. Any ideas?
01-11-2022 02:55 PM
01-11-2022 03:03 PM
PitViper wrote:
Yes the uninstall completed, the install does have issues the first time, rebooted and then it worked. I'll try again. I Installed it on a different PC and it works fine.
The only errors I see are
Faulting application name: ArmouryAudioAgent.exe, version: 1.0.0.8, time stamp: 0x618b6cae
Faulting module name: KERNELBASE.dll, version: 10.0.22000.434, time stamp: 0x78dc11b6
Exception code: 0xc000041d
Fault offset: 0x0013ec52
Faulting process id: 0x1a50
Faulting application start time: 0x01d8072869ea2c11
Faulting application path: C:\Program Files (x86)\ASUS\ArmouryDevice\dll\AudioSDK\AudioAgent\ArmouryAudioAgent.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 964e6992-ab96-4df2-a677-2d4176b22a08
Faulting package full name:
Faulting package-relative application ID:
_______________________________________________________________________________________________________________________________________________________________________
Exception code: 0xc0020001
Report Id: 750b842b-636b-49fa-86af-5cf83051eb30
01-11-2022 08:48 PM
PitViper wrote:
Spent about 8 hours trying to fix it. Gave up and reinstalled windows. Sad too because that was a pretty new install. Anyway it's working now.
