04-17-2024 10:55 PM
Hey guys I rencently install Armoury crate, and when im using my pc and it crash into a weird way, like all of my stuff that can be used are just charging like the cpu doesnt want to do it. Even launching the terminal or the task manager and sometimes it happens in like 30min sometimes in 5h of using my pc im using a DARK HERO VIII EXTREME and a ryzen9 5900x my frequency its always at 4199MHz i find this a bite weird like it use always the max frequency possible on armoury crate and its like my cpu shutdown cause of the things that happens before the shutdown, so I maybe think that this happend cause of a security system where my cpu do to many task with probably I don't know a overvoltage or something like that a security system protect my cpu and so my pc shutdown after a few times cause he cannot communicate with the cpu.
Solved! Go to Solution.
04-17-2024 11:35 PM
Hi @JEYMANUS
This is typical of system instability, can you confirm EXPO is disabled? It's not likely Armoury Crate is causing this behaviour.
04-17-2024 11:35 PM
Hi @JEYMANUS
