10-20-2025 12:27 AM
Motherboard: ROG Strix X870-A Gaming Wifi
I have 1eader, which I've split:
I've only set the fans color to white. When the PC was first built, some fans was showing a hue of white, which I managed to fix by splitting up the number of fans per header evenly, thinking it was some voltage issue.
2 months later (today), the same issue resurfaced, some of the fans in Header 3 is showing a light blue instead of white.
If I open up RGB Signal and lower the brightness to a certain percentage, all the fans does become white at a lower brightness, but that's not what I purchased this motherboard for. Im not planning to use Signal RGB long term and want to control all my RGB settings via Armory Crate only.
