Need help with Armoury Crate and/or Asus Aura
chris_e
Good Evening,
Is there an easy way to remove ALL the Aura Sync and Armoury Crate components from my system and basically start over without doing a full wipe of my OS? I would prefer to get Armoury Crate up-and-running, but would even be satisfied if Aura would consistently run. I would try a full OS re-install, but from what I’ve read, that will not fix the problem.
I recently build a gaming PC. I have never been able to get Aura or Armoury Crate to work properly. I purchased most of the parts because they are supposed to be Aura compatible, but have had nothing but problems. I turned on my system again today, and found that once again, my lighting is messed up and not working properly, but I can’t get Armoury Crate or Aura to install. Aura sometimes installs, but then stops working after a few days. When I try to install Armoury Crate, after I approve the change in the User Account Control, a black System box flashes on the screen, but then nothing happens.
My system has the following components:
• ASUS ROG Strix B450-F Gaming motherboard
• AMD Ryzen 7 2700X processor w/Stock LED Fan
• EVGA GEFORCE RTX 2070 Super FTW3 Ultra Video Card
• 64gb (4x16 sticks) G.Skill Trident Z RGB DDR4-3000 RAM
• Seasonic Focus Gold 650 FX power supply
• Thermaltake Level 20 ARGB case
• DEEP COOL RGB Convertor, 5V ADD-RGB to 12V RGB Transfer Hub (to sync case lighting)
• ROG Evolve Gaming Mouse
• ROG Flare Gaming Keyboard
• ROG Balteus QI LED Mousepad
• Windows 10 64-bit OS
• BIOS is ROG UEFI BIOS Utility Ver 2.17.1246 (ROG Effects are enabled)
note: I am not currently overclocking the system
Some specific issues I've had:
Lighting randomly stops working under both Asus Aura and Armoury Crate
Unable to reliably reinstall Aura and/or Armoury Crate - they sometimes just show up, (Aura usually does allow a reinstall, but not always - then it will run for a few days, and then just stop responding)
G.Skill RAM works, but AURA and Armoury Crate have never 'seen' them, even though they are Aura compatible
When it does work, Aura sometimes reports the Balteous pad as a motherboard
I have tried several methods that I found throughout this (and other) forums, such as:
• Removing the LastProfile.xml (https://rog.asus.com/forum/showthread.php?114101-G-SKILL-Trident-Z-RGB-AURA-NO-CONTROL-%26%2310240%3...)
• Using CCleaner to uninstall the programs and clean the registry (https://rog.asus.com/forum/showthread.php?105774-AURA-SYNC-1-07-22-Report-Issues-Here/page6)
• Uninstalled ALL Aura (and even all ASUS) software, gone through the registry and found all Aura or Lighting Component files and removed them, then cleaned the registry with CCleaner (https://www.reddit.com/r/ASUS/comments/ccnjqh/help_with_aura_software/)
• Uninstalled all Asus programs and reinstalled after checking the "This file came from another computer..." setting in Properties (https://www.reddit.com/r/buildapc/comments/8idiv7/aura_sync_not_recognizing_tridentz_rgb_ram/)
• Cleared the CMOS before reinstalling
• To try to get the RAM synced, I tried to follow these instructions, but do not have a SPD setting in my BIOS (https://forums.tomshardware.com/threads/trident-z-ram-does-not-sync-with-asus-aura-properly.3081990/)
This has been driving me crazy for months. If I would have known that I would have this many issues with the lighting, I would have purchased other products. Does anyone have a solution to get this thing running properly?
Thanks in advance
Chris
18 REPLIES 18
So a power cycle worked in your case?
Polychrome wrote:
Got this message today, and it was seemingly caused by the motherboard being detected as something it was not. I found a fix in another thread here.
Power down your computer. Unplug the power supply from the wall. (Or maybe just turn off your power strip.) Try to turn on the computer. (It will fail and lose power of course, but it drains whatever is left of the power supply.) Give it a little more time. Push the power again for good measure. Then plug in and turn the computer on. It's important that you give it a few seconds rather than just plug it back in right away. (I didn't wait the first time and it didn't work.)
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
Hi Peoples
Today i plugged a 200mm Coolermaster addressable RGB fan onto my Z690-Fs ARGB Socket on the board, i managed to get it powered and lit up however it refuses to change off the colour light blue, i uninstalled armoury, icue and aura Do i need to use some kind of controller or should this be working off the board
The lead is a 3 pin so im guessing thats right
I am seriously losing the plot with these non corsair fans, appreciate any help you can offer
Apologies if i have posted in the wrong place cant see how to start a new topic
RM
MasterC
Community Admin
Community Admin
Here is something you can try:
https://rog.asus.com/forum/showthread.php?128618-Armoury-Crate-v5-1-5-0-Aura-Creator-v3-3-4-Report-h...
You must install Armoury Crate to control the MB lighting, try not installing iCUE. Do not install the old Aura application, all 3 could fight for control over the lighting.
rm43uk wrote:
Hi Peoples
RM
To confirm, your memory issue still exists (can't be seen in Armoury Crate), and now the motherboard isn't recognised either?
Have you tried a power cycle? (Unplug from the wall for 5 seconds then try again).
chris_e wrote:
I am so over this software and hardware.
When I powered my PC up today, I checked the Armoury Crate settings and found a Crate messaging for the motherboard - "This model is not currently supported."
Crate said that the ASUS HAL Central needed to be updated, it took three tries (with reboots) before it finally stuck. It then updated a couple of other components, but the motherboard is still giving the "not supported" message. How can an ASUS ROG branded product not be supported by ASUS ROG software? This is turning into a load of ****.
Here are the diagnostics logs that were requested by MasterC@ASUS.
Item Version
Armoury Crate UWP App 2.7.8.0
ROG Live Service 1.0.28.0
AURA Service (Lighting Service) 3.04.02
Armoury Crate lite service 2.7.10
ASUS AIOFan HAL 1.1.8
ASUS AURA Extension Card HAL 1.0.22
ASUS AURA Motherboard HAL 1.0.64
ASUS Keyboard HAL 1.01.20
ASUS Mouse HAL 1.1.0.17
ASUS MousePad HAL 1.0.2.1
AacVGA 0.0.2.6
KingstonDram 1.0.24
AURA DRAM Component 1.0.42
ENE RGB HAL 1.0.17.0
PHISON HAL 1.0.3.0
Patriot Viper DRAM RGB 1.0.8.2
While I am very frustrated, I do appreciate the help! Thanks!
SilenMar wrote:
Wait for a few days to let Armoury Crate do its thing. It will do some weird stuff very slowly, who knows.
And give it a HOPE that Armoury Crate will automatically update HAL compatible to G-skill memory.
If it doesn't do **** a week later, your memory is not going to work with Armoury Crate.
But you can still have a little FAITH in the legacy Aura Sync files because there are some old-ass HALs in the extracted folder Lighting_Control_1.07.79\LightingService\aac.
You can manually install only AacSetup.exe for the setup of AURA DRAM Component and hope it works this time.
Remember I've never said you should install legacy Aura Sync or other HALs. Don't blame me if you accidentally install Aura Sync out of ROG ****ing FAITH!
So..i did tried to install AacSetup.exe only from legacy Aura Sync files. Nope, doesn't work. Installation cannot be proceed..
MasterC
Community Admin
Community Admin
Please report issues in the official thread. Remember to read the original post for instructions, thanks.
chris_e wrote:
So I was finally able to wipe and reload the OS. I completely wiped the hard drive and reset the BIOS. Now Armoury Crate is up-and-running, it sees (and properly identifies) my Motherboard, Keyboard, Mouse, and Mousepad.
But the G.SKILL Trident Z RAM is still MIA - it is lit and doing the standard rainbow, but Crate doesn't see it even though it is supposed to be compatible with my system.
Any ideas?
Is this problem solve already? I ALREADY COMPLETELY GAVE UP NOW AND START HATING ROG BRAND. A complete re-install windows 11 done with the very first software installed was armory crate. and Nope, RAM still not working. stuck at rainbow. cant do anything...
MasterC
Community Admin
Community Admin
If your issue is still not resolved, please download log tool and follow the instructions in the Readme text file.
Download here:
https://1drv.ms/u/s!AnVh8ZVQZ-1MhL4U89ccbloFhZfMbg?e=R9YCca
After you have done that, please upload the generated log file your cloud storage and PM me the link so we can take a look. Thanks.
MasterC
Community Admin
Community Admin
Hey Chris_e, was your issue resolved?
