05-08-2020 04:04 PM - last edited on 03-06-2024 10:25 PM by ROGBot
05-31-2020 08:48 PM
Polychrome wrote:
Got this message today, and it was seemingly caused by the motherboard being detected as something it was not. I found a fix in another thread here.
Power down your computer. Unplug the power supply from the wall. (Or maybe just turn off your power strip.) Try to turn on the computer. (It will fail and lose power of course, but it drains whatever is left of the power supply.) Give it a little more time. Push the power again for good measure. Then plug in and turn the computer on. It's important that you give it a few seconds rather than just plug it back in right away. (I didn't wait the first time and it didn't work.)
05-14-2022 04:28 PM
05-15-2022 10:26 AM
rm43uk wrote:
Hi Peoples
Today i plugged a 200mm Coolermaster addressable RGB fan onto my Z690-Fs ARGB Socket on the board, i managed to get it powered and lit up however it refuses to change off the colour light blue, i uninstalled armoury, icue and aura Do i need to use some kind of controller or should this be working off the board
The lead is a 3 pin so im guessing thats right
I am seriously losing the plot with these non corsair fans, appreciate any help you can offer
Apologies if i have posted in the wrong place cant see how to start a new topic
RM
05-31-2020 08:56 PM
chris_e wrote:
I am so over this software and hardware.
When I powered my PC up today, I checked the Armoury Crate settings and found a Crate messaging for the motherboard - "This model is not currently supported."
Crate said that the ASUS HAL Central needed to be updated, it took three tries (with reboots) before it finally stuck. It then updated a couple of other components, but the motherboard is still giving the "not supported" message. How can an ASUS ROG branded product not be supported by ASUS ROG software? This is turning into a load of ****.
Here are the diagnostics logs that were requested by MasterC@ASUS.
Item Version
Armoury Crate UWP App 2.7.8.0
ROG Live Service 1.0.28.0
AURA Service (Lighting Service) 3.04.02
Armoury Crate lite service 2.7.10
ASUS AIOFan HAL 1.1.8
ASUS AURA Extension Card HAL 1.0.22
ASUS AURA Motherboard HAL 1.0.64
ASUS Keyboard HAL 1.01.20
ASUS Mouse HAL 1.1.0.17
ASUS MousePad HAL 1.0.2.1
AacVGA 0.0.2.6
KingstonDram 1.0.24
AURA DRAM Component 1.0.42
ENE RGB HAL 1.0.17.0
PHISON HAL 1.0.3.0
Patriot Viper DRAM RGB 1.0.8.2
While I am very frustrated, I do appreciate the help! Thanks!
05-05-2022 06:29 AM
SilenMar wrote:
Wait for a few days to let Armoury Crate do its thing. It will do some weird stuff very slowly, who knows.
And give it a HOPE that Armoury Crate will automatically update HAL compatible to G-skill memory.
If it doesn't do **** a week later, your memory is not going to work with Armoury Crate.
But you can still have a little FAITH in the legacy Aura Sync files because there are some old-ass HALs in the extracted folder Lighting_Control_1.07.79\LightingService\aac.
You can manually install only AacSetup.exe for the setup of AURA DRAM Component and hope it works this time.
Remember I've never said you should install legacy Aura Sync or other HALs. Don't blame me if you accidentally install Aura Sync out of ROG ****ing FAITH!
05-15-2022 10:18 AM
RsdFnd wrote:
So..i did tried to install AacSetup.exe only from legacy Aura Sync files. Nope, doesn't work. Installation cannot be proceed..
05-05-2022 06:23 AM
chris_e wrote:
So I was finally able to wipe and reload the OS. I completely wiped the hard drive and reset the BIOS. Now Armoury Crate is up-and-running, it sees (and properly identifies) my Motherboard, Keyboard, Mouse, and Mousepad.
But the G.SKILL Trident Z RAM is still MIA - it is lit and doing the standard rainbow, but Crate doesn't see it even though it is supposed to be compatible with my system.
Any ideas?
06-03-2020 10:09 PM
