my ARMOURY CRATE LOOKS WEIRED AND NOT SHOWING ANY SYSTEM USAGE
shubham-
i dont know whats wrong  i only updated it when it showed up
11 REPLIES 11
masyh1997
this update have many bugs , please check do you have AI noise cancelling?
i do everything else is there accept the system status
LOCOB2
i have same problem too, please tell me wht to do to fix this
Metasion
same issue for me too, can anyone help me with that
StevenC15
i have the Same issue , i reinstall it but still can't fix . anyone can help asus ?
Piyush2006
same problem after update it does n't showing nothing
mailtomathan313
same problem im facing too  ( not showing system usage )
mollyroy82
same problem, any solutions
ddraig7
i found the fix guyssss
1. go to your armoury crate's settings and check for updates
2. install all the update including aura and others
3. open armoury crate again
this will fix the problem.. XD
make sure you have updated your graphics drivers
