03-27-2025 05:40 AM
So... I recently upgraded my pc with an asus rog Mobo, it came with armoury crate, i had issues with performances so i uninstalled it.
now i want to install it back but it wont work : when i install armoury crate + aura, it says that the "asus services are unavailable restart ur pc" I do, and then they say to reinstall , doesnt work.
so I tried the full package installation. Wont install "Windows is busy error 200_3"
i'm getting so pissed, i've been looking for answer everywhere, i've tried reinstalling so many Times, i tried to disable antivirus app and other things i could find but nothing work, idk what to do anymore.
03-27-2025 06:15 AM
Hello lifthrasir
Try this:
1) Run the Armoury Crate uninstall tool. In the link, click "Show all" in blue, it's the 4th download. - Armoury Crate - Support
2) Restart your pc.
3) Install Armoury Crate version 3.3.1.0 (First download) - Armoury Crate - Support
How does this go?
03-29-2025 08:24 AM
I've tried this countless and countless times, it doesnt work.
03-29-2025 08:26 AM
I've tried to normal installing, the full package, uninstalling with the uninstall tool , restarted, tried again, same result :
when i install the normal one : asus services unavaible, and there are no devices that are detected.
And i cant Even install the full package
03-29-2025 11:55 AM
Thank you
Which ROG Motherboard do you have?
When upgrading to a new motherboard, you always want to do a fresh install of windows, just making sure you've done this.
Since you're having such issues, it wouldn't be a bad idea to reinstall windows. Just before the windows install, you'll get an option to delete all partitions on your drive, be sure to delete all partitions.
Once windows is installed, make sure windows is fully updated, then install Armoury Crate.
Should only take 10-15 minutes to reinstall windows.
Does this get Armoury Crate to install?
