H370 PRO-GAMING WIFI INTEL CHIPSET DRIVER OUTDATED PROBLEM
MASH777
I hope somebody could help me with this intel chipset driver 10.1.17541.8066 current version 10.1.16.7. It is prompted in driver update tool of armoury crate. However, every time i select update and finish installing then restart. It is still prompted in armoury crate as outdated. Below is the photo of the details in armoury crate bios and all is up to date along with the other drivers except for this one.367392098_665243822448130_9033434682677027397_n.jpg400216286_1094599138391697_9099952078136675880_n.jpg
Nate152
Hello Mash777
Try installing the chipset driver from the ASUS Support Center.
TUF H370-PRO GAMING|Motherboards|ASUS Global
Here is the latest version.
Thank you for the response nate. I have already tried that and its prompting me to downgra400500928_993992571703035_9031641732092348602_n.jpg386881490_742167154395837_1366232328882046969_n.jpg371910781_7100926199946902_8666757940929637864_n.jpgde the chipset driver because i have the latest one but armoury crate is opting me to upgrade but after several times of trying its still showing the same version to upgrade again.
Nate152
What you have circled is the Intel Management Interface driver. If it's giving you the downgrade message, it doesn't need updated and is fine to leave as is.
I personally install the drivers from the ASUS Support Center and ignore any outdated drivers in Armoury Crate.
