Gladius III aimpoint disconnecting issue
ysh9319
I recently got my broken Gladius III replaced with Gladius III aimpoint. And when used, the mouse is intermittently disconnected and then reconnected. I don't know what the problem is because this disconnect happens randomly. Then, when this disconnection occurred, I saw that the lighting of the computer linked to the aura sync was reorganized collectively. So I suspect this problem is caused by Armory Crate. There seems to be a user who has experienced similar symptoms in the forum, but the user has not solved it either. Is there a user who is experiencing the same problem as me? If so, please share the solution.
This issue occurs regardless of wired or wireless. And i clean install window 11
My computer info
Cpu : 5800x
M/B : asus x470 i gaming
Gpu : asus 6700xt strix
Ram : gskill trident z 3200mhz cl14(16x2)
Power : seasonic focus 850w gold
Ssd : skhynix p31 2tb
j87gy
Thank you for posting. I have the exact se problem. The mouse will become unresponsive randomly.
Asus, please fix!!!
