I'm having an issue with Armory Crate and controlling my Ryujin Fans.
It was working fine but yesterday i had to unplug the aio fan controller to do some cable management..
The fans started to act out, not spinning or one or 2 out of 3
.After a wihile they manage to spin again but now they are detected as maxing at 570 RPM
It's litteraly driving me crazy , It was working fine and of course i tried to do it better and now it's all messed up.
What i tried:
- Plug one fan on each header of the controller instead of using the splitter
- Uninstall armory crate multiple times with the uninstaller / reinstall it
-I run the fans on the CPU header, they work fine
- I did a system restore of few days ago, same issue.
- Tried with another AIO controler since i have a spare one, i had to rma another unit for a noise issue and haven't send the previous AIO to Amazon (the pump on the new one is indeed a LOT more silent)
but it's not fixing it.
So : it's not the fan, it's not the controller.
The pump and embedeed fan of the AIO are working fine and can be controlled.
I know I can just use the fan on the cpu header with the splitter, it's even better since temps in Armory Crate are 10C lower than they are for real but i hate having something not working as it should be in my rig
🙂I'm considering doing a clean reinstall of the OS, but if someone knows what could be the issue...
Thanks !
