Fan Xpert does't work in Armoury Crate
emkdrl07
Level 11
Hey, I cannot run Fan Xpert in Armory Crate. So many times i have uninstalled AC with Armoury Crate Uninstall Tool then installed but not changed. it's really annoying i would appreciate it if you could help me.
Item Version
Armoury Crate UWP App 5.3.4.0
ROG Live Service 1.6.4.0
Aura Service (Lighting Service) 3.05.78
Armoury Crate lite service 5.3.3
Aura Wallpaper Service Yüklü değil
ASUS AIOFan HAL 1.1.50.0
ASUS AURA Extension Card HAL 1.1.0.18
ASUS AURA Motherboard HAL 1.3.9.1
ASUS Keyboard HAL 1.2.23.0
ASUS Mouse HAL 1.2.0.58
ASUS MousePad HAL 1.0.3.5
AacVGA 0.0.5.8
KingstonDram 1.1.18
AURA DRAM Component 1.1.23
ENE RGB HAL 1.1.40.3
ENE_EHD_M2_HAL 1.0.10.1
PHISON HAL 1.0.9.0
Patriot Viper DRAM RGB 1.0.9.5
Patriot Viper M2 SSD RGB 1.1.0.2
Universal Holtek RGB DRAM 1.0.0.4
WD_BLACK AN1500 1.0.14.0
85 REPLIES 85
Gobbo
Z690 Extreme, same extremely annoying issue
chris-piekarski
When will this be fixed?
Logue
It worked until around August, but since then the heatsink fan has been grayed out and always rotates at maximum speed.
To be precise, it seems that the heatsink fan cannot be recognized by the OS.
I have no choice, so I disable Xpart and use FanControl.
Peppe75
if I try to manually install aisuite3 or fanexpert I get this error
jason_mulree
Seriously Asus, how bloody hard can it be to fix the issues with Fan Xpert, issues that did not exist until August? Even the latest version of Armoury Crate released in the last day fails to resolve issues!
Whatever changes were rolled out in August caused my issues with others reporting the same and while I understand that not everyone is having issues, there are enough people who are to warrant the ability to rollback to a version that worked for them. There is nothing more frustrating then to have things working well, being forced to update, then having those updates break things.
I seriously regret investing in the purchase of  Asus components for my build and will probably consider other brands in future.
I doubt anyone from Asus will read this let alone take any action to really fix the issues anytime soon, but one can only hope. I feel better for venting and sometimes knowing that others are in the same situation makes me feel better about my own.
jzer0912
Bunch of recent updates, including Fan Xpert (Oct 16th).  Still broken, same error: S-1001.   Tried full uninstall with uninstall tool, reinstall with latest installer.  No dice.
Updated on Z790 Extreme and FanXpert still doesn't work.  Same error S-1001
HI! I had the same annoying problem about fan xpert didn't work in Armoury Crate after uninstall and reinstall all the asustek software (AI suite, services, rog, etc...). I even changed the factory rgb controller for another one and also changed the fan dc connection to another mother board socket.
Finally, I've solved the problem by disabling Fan Xpert fan control switch in order to control fans from bios. I've entered Bios by pressing F2 and set the CHA FAN channel of the fans to PWM instead of autodetect and in inmediately fans changed from full speed to the selected on Q control of the bios. Once changes saved and computer restarted, I've reactivated Fan Xpert fan control switch and tuned again fan speed, and now I can change fan speed with armoury crate controls without any issues.
In my case I have an Asus TUF GAMING B760M Plus Wifi mother board
I've noticed that argb controller cable has only 2 wire instead fans have 3 or four pins. This could be the reason because bios fan autodetect fails on settings the appropriate method
emkdrl07
Level 11
Asus makes great hardware but the software is truly terrible. I made all my hardware asus to control it all with a single program. My hardware is listed below. I installed Armory Crate and Armory Crate, but Asus manages to break something with every update, congratulations. However, I really regret it, I will DEFINITELY not buy ASUS hardware from now on.
MB: ASUS ROG Crosshair X670E Hero
CPU: AMD Ryzen 5 7600X
GPU: ASUS TUF 4070 Ti
Liquid Cooler: ASUS ROG Ryujin III 360mm ARGB
Mousepad: ASUS ROG Balteus Qi
Mouse: ASUS ROG Chakram X
Keyboard: ASUS ROG Claymore II
Memory: G.SKILL Trident Z5 Neo RGB DDR5-6000 CL36-36-36-96 1.35V 32GB (2x16GB)
Case: ASUS ROG Strix Helios
MasterC
Community Admin
Community Admin
AiSuiteSDK v1.01.14 was published yesterday, please update. Thanks for your patience.
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
