Fan Xpert does't work in Armoury Crate
emkdrl07
Level 11
Hey, I cannot run Fan Xpert in Armory Crate. So many times i have uninstalled AC with Armoury Crate Uninstall Tool then installed but not changed. it's really annoying i would appreciate it if you could help me.
Item Version
Armoury Crate UWP App 5.3.4.0
ROG Live Service 1.6.4.0
Aura Service (Lighting Service) 3.05.78
Armoury Crate lite service 5.3.3
Aura Wallpaper Service Yüklü değil
ASUS AIOFan HAL 1.1.50.0
ASUS AURA Extension Card HAL 1.1.0.18
ASUS AURA Motherboard HAL 1.3.9.1
ASUS Keyboard HAL 1.2.23.0
ASUS Mouse HAL 1.2.0.58
ASUS MousePad HAL 1.0.3.5
AacVGA 0.0.5.8
KingstonDram 1.1.18
AURA DRAM Component 1.1.23
ENE RGB HAL 1.1.40.3
ENE_EHD_M2_HAL 1.0.10.1
PHISON HAL 1.0.9.0
Patriot Viper DRAM RGB 1.0.9.5
Patriot Viper M2 SSD RGB 1.1.0.2
Universal Holtek RGB DRAM 1.0.0.4
WD_BLACK AN1500 1.0.14.0
85 REPLIES 85
3DCairns
@AzovNazis How did you manage that? On Z690-I board you can open Fan Xpert and set the RPM now?
https://www.filehorse.com/download-asus-fan-xpert/download/ )Download it from the link, I was prompted and earned it. Delete the old WHOLE and COMPLETELY Armoury_Crate , download it and install fan xpert 4 from there , without the Internet .I haven 't tried updating it yet . Mr. Putin suggested it to me .And he asked me to prescribe a slap on the head to the director of the ACS for such an expensive product that costs a lot of money and ХУЁВА РАБОТАЕТ!!! .Distribute it to everyone as I wrote
AzovNazis
( https://www.filehorse.com/download-asus-fan-xpert/download/ )Download it from the link, I was prompted and earned it. Delete the old WHOLE and COMPLETELY Armoury_Crate , download it and install fan xpert 4 from there , without the Internet .I haven 't tried updating it yet . Mr. Putin suggested it to me .And he asked me to prescribe a slap on the head to the director of the ACS for such an expensive product that costs a lot of money and ХУЁВА РАБОТАЕТ!!! .
unfortunately other people need some additional functionality provided by AC so we are all hoping Asus can fix this issue.
For me fan xpert works after fresh AC install until I do a system reboot, then AC won't be able to load anymore.
I had submitted logs to Asus but looks like there is no update...
I have installed as in my description .I reinstalled over the usual installer (just to check how the software behaves ) and updated the program and rebooted the PC , all functions work .Asus b650e .By the way, the bios firmware did not help
AzovNazis
I wrote
PlanetDyna
I buy a high-end mainboard - and ASUS didn't even reply that they are working on it. Really sad. Should I buy a new motherboard now?
ASUS have lost the edge. Okish hardware, horrible software and support.
If you have money, then buy another company, Aorus or another .Have you not fixed it according to my method ? everything is already working for me .
pixielark
The july 19 FX plugin update fixed my Fan Xpert on my Z690i, so whoever has Fan Xpert problem should try to update and report again if you still have problem
