02-15-2023 12:50 PM
02-18-2023 11:39 PM
02-19-2023 07:44 AM
emkdrl07 wrote:
Hey, i uninstalled GeForce Experience. Then i did the windows features .NET 3.5 and .NET 4.8 advanced off and back on. Then i rebooted and runed automatic system maintenance uninterrupted. Took of 15 minutes. Then i runed the Armoury Crate installer a couple of times in row without uninstalling. Thats not succeed!
Then i did orijinal cleaning steps. And i have installed AI Suite 3 (v3.03.17 or v3.03.07 doesnt matter). It provided an AsusFanController.exe(I have attached the picture below). Then i installed AC. Thats not succeed again.
Thank you very much for taking the time to help.
But, i installed GeForce Expreince(because i use it) and i did open windows update. I'm so tired, bored and angry. I want to share something with you sincerely. I have used MSI products (motherboard and video card) for many years. My keyboard, mouse, liquid cooler etc. products were different. I had to install multiple different programs. I said that all my products should be from the same brand and I would control them with a single software. And I chose the ASUS brand because it made really quality hardware. All my hardware is ASUS ROG(Motherboard, Graphic Card, AIO, PSU, Mouse, Mouse Pad, Case). As you can imagine, I paid a lot of money for these. However, Armory Crate is a really infamous program. I'm really sorry. I've never worked this hard before. I am really tired and bored. I guess my only solution is to reinstall windows. But reinstalling windows for every problem is a ridiculous thing. I request you to report this problem to Asus software team if you have the opportunity. I would be very happy if you fulfill this request.
02-19-2023 08:38 AM
Jimbo93 wrote:
I understand the frustration. I would have never worked out my understanding of how to uninstall it if it wasn't for many many hours of that. It does seem like you had a good understanding of the instructions. But more feedback about any errors or other observations would be needed. Really I am just guessing about the situation. Perhaps it is the only route to do a reinstall of the OS.
On my system I have not had to reinstall the OS now for over a year, even though for much of that time I was unhappy with some of my system performance, that is Wi-FI has been particularly finicky/problematic, the windows security app has had a malfunction and crashed on device security page, and certain performance was quite inconsistent. It is only relatively recently that I am very happy and after much work have resolved all my issues. The issues were not caused by Armoury Crate even though it was Armoury Crate that sometimes exposed/revealed them. Good Luck.
03-23-2023 10:23 AM
Hey,
But the product(ROG RYUJIN II 240 ARGB) page states that Fan Xpert 4 supports it. I also added the picture.
4 weeks ago
Any news on this error? I build a brand new high end system, and it is very frustrating Fanexpert is not running....( I do not have any other Fan or hub software running....Strix Z790-F)
4 weeks ago
After i warned them, they fixed the RYUJIN II page and removed the FanXpert 4 compatibility article. As a result, RYUJIN II is not compatible with FaXpert 4. You right, really annoying
3 weeks ago
I have ascended from the depths of Asus by using https://getfancontrol.com/
for controlling any and all fans and Rad Pumps.
For RGB...I am forever a slave to https://signalrgb.com/
(In a Maui accent): You're welcome!!
