12-10-2024 12:22 AM
The setting from which thermal sensor to take data from chassis fan 1 is not saved after the system is rebooted. Every time you have to go into the program and change it, and all the time the CPU is automatically set there.
12-10-2024 02:23 PM
let me check on that using the same channel source. what sensor you select. In my case i remove the cpu and put motherboard since i have gpu also reading. I will report back in a few hours.
12-10-2024 10:47 PM
I use dram sensor on ddr5
12-11-2024 02:45 AM - edited 12-11-2024 02:46 AM
the ram sensor was reported some time ago. once selected will remove on restart or turn on the pc. that i mentioned and reported it. there was a update today let me test again. But if that was the one with issues, why did you not say it?
let start again
12-10-2024 10:54 PM
Can you use only one sensor for test? not CPU and 1 more
12-18-2024 08:13 AM
I'm having the same issue. I use chassis 3 fan as a ram cooling fan and whenever I select ddr temp in armoury crate it does not save it. Every time after rebooting it switches to cpu again. I also can't select temp source as ram in bios it doesnt show up there. The default temp source for chassis fans are cpu so I guess it just overwrites it. Would be great to have a fix for it.
12-18-2024 01:42 PM
for ram sensor NOP. i send that report some time ago.
