EK AIO Elite Pump RGB doesn't work when basic effect set to anything except Static
Planeswalker11
Hi there,
I just updated Armoury Crate to 5.1.5.0 and now the RGB lighting on my EK AIO Elite D-RGB pump block doesn't work when I set the lighting effects to anything except Static. So it doesn't work when the basic lighting is set to breathing, strobe, rainbow, etc. It was working fine on the last version of the app. I've also tried using Aura Creator to set the addressable header to Static but it doesn't light up at all with Aura Creator. My other components work just fine. I don't get any error pop ups or other issues.
I've fully uninstalled and reinstalled both Armoury Crate and Aura Creator multiple times using the uninstall tool and it hasn't fixed the issue.
Item Version
Armoury Crate UWP App 5.1.5.0
ROG Live Service 1.4.5.0
Aura Service (Lighting Service) 3.05.40
Armoury Crate lite service 5.1.4
Aura Wallpaper Service Not installed
ASUS AIOFan HAL 1.1.45.0
ASUS AURA Extension Card HAL 1.1.0.18
ASUS AURA Motherboard HAL 1.2.8.0
AacVGA 0.0.4.3
KingstonDram 1.1.12
AURA DRAM Component 1.1.18
ENE RGB HAL 1.1.39.15
ENE_DRAM_RGB_AIO 1.0.0.10
ENE_EHD_M2_HAL 1.0.9.12
PHISON HAL 1.0.9.0
Patriot Viper DRAM RGB 1.0.9.2
Patriot Viper M2 SSD RGB 1.0.6.5
Universal Holtek RGB DRAM 1.0.0.2
WD_BLACK AN1500 1.0.14.0
Thanks.
4 REPLIES 4
alin_eusebie
I have the same problem with RGB is on rainbow end I can not change the mod, after the last update !
I have the same problem, after updates constantly pop up some bugs
Planeswalker11
Updating BIOS on my board fixed it.
asharhs
Hey there, Plaenswalker11
It's frustrating when your RGB setup goes awry, but I might have a solution for you. Your issue with the EK AIO Elite D-RGB pump block not lighting up properly after updating Armoury Crate to version 5.1.5.0 could be related to software conflicts or settings discrepancies. Here's what I recommend:
1. Check for Compatibility: Ensure that the firmware of your EK AIO is up to date and compatible with the new version of Armoury Crate. Sometimes, firmware updates are necessary for proper functioning.
2. Driver Updates: Make sure your GPU and motherboard drivers are also up to date, as they can affect RGB control.
3. BIOS Settings: In some cases, BIOS settings can impact RGB performance. Check if there are any relevant settings in your BIOS and ensure they are correctly configured.
4. Revert to Previous Version: If none of the above works, consider reverting to the previous version of Armoury Crate that was working fine for you until a stable update is available. Sometimes, new updates can introduce bugs.
As for my experience, I've encountered similar issues before, and these steps usually helped me resolve them. It's a trial-and-error process, but it should get your RGB back to its dazzling self.
